メインコンテンツにスキップ
Xbox One Elite Controller (Model 1698) LED Replacement
必要な工具と部品
  1. Xbox One Elite Controller (Model 1698) LED Replacement, Show me the Screws!: 手順 1、 2の画像 1 Xbox One Elite Controller (Model 1698) LED Replacement, Show me the Screws!: 手順 1、 2の画像 2
    • You can remove the side panels with a pry tool.
    • You don't need to remove the rubber. The rubber on this controller was already bad
  2. Xbox One Elite Controller (Model 1698) LED Replacement, Removing the back panel screws: 手順 2、 1の画像 1
    • Remove the 5 Torx Security Bit (TR9) screws
  3. Xbox One Elite Controller (Model 1698) LED Replacement, Popping that back panel off: 手順 3、 3の画像 1 Xbox One Elite Controller (Model 1698) LED Replacement, Popping that back panel off: 手順 3、 3の画像 2 Xbox One Elite Controller (Model 1698) LED Replacement, Popping that back panel off: 手順 3、 3の画像 3
    • Pry the panel next to the 3.5mm port
    • Be careful to not rip the ribbon shown in the next step
  4. Xbox One Elite Controller (Model 1698) LED Replacement, Warning Carefully remove the ribbon: 手順 4、 2の画像 1 Xbox One Elite Controller (Model 1698) LED Replacement, Warning Carefully remove the ribbon: 手順 4、 2の画像 2
    • Be careful to not rip the ribbon cable
    • You can pop the connector up to remove the ribbon easily
    • Ribbon Cable
  5. Xbox One Elite Controller (Model 1698) LED Replacement, Screws on controller motherboard: 手順 5、 1の画像 1
    • Remove the 2 Torx (T6) screws
  6. Xbox One Elite Controller (Model 1698) LED Replacement, Desolder wires from motherboard: 手順 6、 2の画像 1 Xbox One Elite Controller (Model 1698) LED Replacement, Desolder wires from motherboard: 手順 6、 2の画像 2
    • Desolder the 4 wires on each side, these control the vibrations and the RT LT
  7. Xbox One Elite Controller (Model 1698) LED Replacement, Remove the motherboard: 手順 7、 2の画像 1 Xbox One Elite Controller (Model 1698) LED Replacement, Remove the motherboard: 手順 7、 2の画像 2
    • Pull up from the "top" side of the controller on the sister board.
  8. Xbox One Elite Controller (Model 1698) LED Replacement, Remove the Home Button Cover: 手順 8、 3の画像 1 Xbox One Elite Controller (Model 1698) LED Replacement, Remove the Home Button Cover: 手順 8、 3の画像 2 Xbox One Elite Controller (Model 1698) LED Replacement, Remove the Home Button Cover: 手順 8、 3の画像 3
    • Be Careful to not lose the sync button
    • Pry the middle section up from the home button side.
    • This will also remove the LB and RB which is a single part
  9. Xbox One Elite Controller (Model 1698) LED Replacement, Remove the controller daughterboard: 手順 9、 2の画像 1 Xbox One Elite Controller (Model 1698) LED Replacement, Remove the controller daughterboard: 手順 9、 2の画像 2
    • Unscrew the 6 Torx (T6) screws
  10. Xbox One Elite Controller (Model 1698) LED Replacement, Replace the LED: 手順 10、 1の画像 1
    • Desolder the original LED from the motherboard of the controller. Do this for both sides of the LED until all of the old solder is removed.
    • Solder on your new LED.
    • Make sure it is installed the same direction as the old LED, or you can burn out the new LED.
終わりに
6 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
EasyAsABC123
メンバー登録日: 01/22/10
2,407 ポイント
5のガイドは作成済み
7 件のコメント
So question I’m having troubles with my elite controller every time I go to plug it in and the charging port in the back of the controller it starts to smoke what’s my problem
Dustin Dykstra - 返信
It sounds like it could be a lot of things…
smoke is obvious a dead stop (stop plugging it in until you repair it).
I would first check the charge port and make sure it is firmly attached if it isn’t you can easily replace the usb port. Next it could be the mainboard charging circuit. if it is this…replace the controller is likely the ideal solution.
EasyAsABC123 -
I was looking to do this mod for fun. Do you have or know where I can get the led part number? A schematic or bom would be nice. Thanks
Clayton Armagost - 返信
Thank you. I ordered them so we will see what happens.
Clayton Armagost -
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 33
今までの合計 6,294
