メインコンテンツにスキップ
Xbox One Elite Controller (Model 1698) Daughterboard Replacement
必要な工具と部品
  1. Xbox One Elite Controller (Model 1698) Daughterboard Replacement, Show me the Screws!: 手順 1、 2の画像 1 Xbox One Elite Controller (Model 1698) Daughterboard Replacement, Show me the Screws!: 手順 1、 2の画像 2
    • You can remove the side panels with a pry tool.
    • You don't need to remove the rubber. The rubber on this controller was already bad
  2. Xbox One Elite Controller (Model 1698) Daughterboard Replacement, Removing the back panel screws: 手順 2、 1の画像 1
    • Remove the 5 Torx Security Bit (TR9) screws
  3. Xbox One Elite Controller (Model 1698) Daughterboard Replacement, Popping that back panel off: 手順 3、 3の画像 1 Xbox One Elite Controller (Model 1698) Daughterboard Replacement, Popping that back panel off: 手順 3、 3の画像 2 Xbox One Elite Controller (Model 1698) Daughterboard Replacement, Popping that back panel off: 手順 3、 3の画像 3
    • Pry the panel next to the 3.5mm port
    • Be careful to not rip the ribbon shown in the next step
  4. Xbox One Elite Controller (Model 1698) Daughterboard Replacement, Warning Carefully remove the ribbon: 手順 4、 2の画像 1 Xbox One Elite Controller (Model 1698) Daughterboard Replacement, Warning Carefully remove the ribbon: 手順 4、 2の画像 2
    • Be careful to not rip the ribbon cable
    • You can pop the connector up to remove the ribbon easily
    • Ribbon Cable
  5. Xbox One Elite Controller (Model 1698) Daughterboard Replacement, Screws on controller motherboard: 手順 5、 1の画像 1
    • Remove the 2 Torx (T6) screws
  6. Xbox One Elite Controller (Model 1698) Daughterboard Replacement, Desolder wires from motherboard: 手順 6、 2の画像 1 Xbox One Elite Controller (Model 1698) Daughterboard Replacement, Desolder wires from motherboard: 手順 6、 2の画像 2
    • Desolder the 4 wires on each side, these control the vibrations and the RT LT
  7. Xbox One Elite Controller (Model 1698) Daughterboard Replacement, Remove the motherboard: 手順 7、 2の画像 1 Xbox One Elite Controller (Model 1698) Daughterboard Replacement, Remove the motherboard: 手順 7、 2の画像 2
    • Pull up from the "top" side of the controller on the sister board.
  8. Xbox One Elite Controller (Model 1698) Daughterboard Replacement, Remove the Home Button Cover: 手順 8、 3の画像 1 Xbox One Elite Controller (Model 1698) Daughterboard Replacement, Remove the Home Button Cover: 手順 8、 3の画像 2 Xbox One Elite Controller (Model 1698) Daughterboard Replacement, Remove the Home Button Cover: 手順 8、 3の画像 3
    • Be Careful to not lose the sync button
    • Pry the middle section up from the home button side.
    • This will also remove the LB and RB which is a single part
  9. Xbox One Elite Controller (Model 1698) Daughterboard Replacement, Remove the controller daughterboard: 手順 9、 2の画像 1 Xbox One Elite Controller (Model 1698) Daughterboard Replacement, Remove the controller daughterboard: 手順 9、 2の画像 2
    • Unscrew the 6 Torx (T6) screws
終わりに
2 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
EasyAsABC123
メンバー登録日: 01/22/10
2,407 ポイント
5のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 14
過去 30 日: 78
今までの合計 8,285
