はじめに
このガイドを使ってXbox Oneのマザーボードを交換します。
CPUからヒートシンクを取り出してしまうと、塗布された本来のサーマルコンパウンド機能を失ってしまいますのでご注意ください。そのため新しく放熱グリスを塗布する必要があります。取り出した箇所を綺麗に拭いて、放熱グリスを付けます。 塗布方法のガイドについて参照ください。
必要な工具と部品
正面パネルの基板からスピーカーケーブルのコネクターの接続を外すため、ゆっくりと引き抜きます。
スパッジャーの平面側先端を使って、アンテナケーブルを正面パネルの基板から接続を外します。
以下の翻訳者の皆さんにお礼を申し上げます:
100%
翻訳を始める ›
7 件のコメント
Quick question. After reassembly do you need to reinstall an operating system or update anything thing or does the hard drive just go oh look new stuff yeah that's fine.
Matt Glenn - 返信
It depends - the hard drive needs to have it’s operating system files up to date to match whatever is flashed onto the motherboard. If the two dont match you get error E106. You can solve this https://support.xbox.com/en-US/xbox-one/...
My Xbox 1 will turn on and within 2 mins or less back off on it's on. I know for a fact it's not the power source, brick or cords. They work on another console. Any info would be awesome. Thanks!
Brian, same issue here. I replaced capacitors on my brick last year and works on another console. I have tried numerous reset options as well. I opened up and cleaned dust out with air compressor and 99% isopropyl alcohol. I also replaced the thermal paste on the processor and removed old paste carefully with alcohol. It still does the same thing like yours above. Turns on, fan turns on, no display, then turns off within 1-2 minutes. None of what I did above changed it, so decided between replacing motherboard or hard drive. I have my Xbox connected to external USB SSD, but still no avail. Not sure if my external had the OS on it though.
Have any of you had issues even after replacing the motherboard? Like, did it go out on you a couple months later? Did it still run the same? Time sensitive question please answer, thanks! Can't keep checking, o if you have an answer please contact me on Instagram at ugli_boi99
