はじめに
ファンに雑音が混じったり、機能しない場合は、このガイドを使ってファンを取り出したり交換します。
必要な工具と部品
プラスチック製の開口ツールを使って、 USBポート側のパネル周辺のプラスチックベントをこじ開けて取り出します。
このベントはとてもフレキシブルです。そして軽いプラスチッククリップで固定されていますー裏側からこじ開けて全体を持ち上げます。
- 플라스틱 오프닝 도구를 애용해서 측면 usb 포트를 둘러싼 통풍구를 들어올려 분리하세요.
- 이 통풍구는 무척 유연하며 연약한 플라스틱 클립으로 고정되어 있습니다. 뒤쪽에서부터 들어올려 분리하고 떼어냅니다.
タブをまっすぐ後ろ向きにスライドして外します。
Here is What's Stated in Step-3 : (There is a small plastic tab that reinforces the front corner of the Xbox.) Actually, the "Tab" is NOT SMALL at all. See the Picture: The "TAB" is the Piece that this Person has their Thumb on, is the Tab that you NEED TO SLIDE TOWARDS THE "REAR" of the Unit. You will be able to tell How this Large Tab Holds the Top and the Bottom Case Covers together. Take Note how to Replace this tab back where it Belongs, when you are putting the Case Covers back together. Hope that this comment will help you. 6-29-2017
- xbox의 전면 모서리를 지지하는 작은 플라스틱 탭이 있습니다.
- 뒤쪽으로 똑바로 밀어서 제거하세요.
What is this small tab referred to as?
What is it called i need to order one.
スパッジャーの平面側先端を上部と下部ケースの間、ベント開口側に差し込みます。
prying does not work. my spudger is causing damage. my soft. plastic. spudger. and the %#*@ thing does not move. this is a common issue with the instructions on this site. you write instructions like you assume people have extensive repair experience. describe the plastic tab. add detail. because simply prying WILL damage the case. hire a %#*@ writer. cause you guys do not know how to precisely convey important detail. constant problem with tech companies actually. no writers.
- 벗겨낸 통풍구쪽부터 상판과 하판 사이의 틈으로 spudger의 평평한 끝을 밀어넣습니다.
- 플라스틱 클립들이 꽤 강하기 때문에 생각보다 강한 힘을 사용해야 합니다.
- 케이스를 완전히 열 때까지 spudger를 계속 끼워두세요. 클립이 강해서 작업도중 다시 닫힐 수도 있습니다.
it would be very very nice that the part, that you sell, will Fix. This an ols Tutorial. The new opening tools that you sell, will not help anything, cause there is no flat sign on the side. you link these tools at this tutorial, but never tested, if the new tools work. so i tell this you, no they dont fit. Thanks for nothing.
I ve made it this far with only a Lego membership card and a flimsier amusement park card (I'm a big year old)
I had to use a 1/32nd flathead screw driver. In the corner to get it started push the top joint of the case down and up will simultaneously pulling up and down to seperate the seam. You will need a 3rd hand to insert the 1/32nd flathead and pry up to get the case started.
I had a virgin never opened xbox day one og so that might be why I had to do it this way.
even the wikihow instructions are better
It’s easier if you push the top empty area part of the plastic with your finger, and stick the spudger about 3/4” (2 cm) away from the back of the xbox and start prying. You have to do this because that is the only spot where there are no clips in the way. If you do any less or more distance, the clips are in the way, and you’ll never be able to pry open the Xbox because the tool can’t get in.
A youtube video I found explains this step better. You are meant to pull up on one half and push down on the other, this separates the two halves. Then use a spudger on the rear of the console to separate the clip right under the warranty sticker, then move down the back of the console to the other clips
上下ケースの間にプラスチックの開口ツールを差し込んで、背面側のベントに向かってクリップを外します。
- 상판과 하판 사이에 끼인 후면 단자판은 여러개의 클립으로 고정되어 있습니다.
- 플라스틱 오프닝 도구로 후면 통풍구의 클립들을 분리하세요.
Xboxの裏側に沿って、クリップをこじ開けながらスライドします。
- 후면을 따라서 계속 클립을 들어서 분리하세요.
- spudger가 제대로 꽂혀 있는지 중간중간 확인하세요. spudger가 빠질정도로 케이스가 분리 되더라도 남은 클립들이 매우 탄력적이라서 방심하면 도로 닫히기 십상입니다. 원활한 진행을 위해 spudger가 잘 꽂혀서 사이를 벌리도록 유지하세요.
クリップが閉じてしまうので、クリップの真横にプラスチック製開口ツールをスライドすると簡単になります。
- 클립들을 계속해서 분리합니다. 클립들을 가로질러 플라스틱 오프닝 도구를 주욱 미는 것이 도움이 될수도 있습니다.
- 후방 케이스를 따라 분리하면 상판이 열릴 기미가 보여야 합니다. 만약 열릴 기미가 보이지 않는다면 모서리부터 플라스틱 오프닝 도구로 분리를 시작하고 usb포트가 없는 쪽을 따라서 클립 분리를 다시 시도하세요.
差し込んだままのスパッジャーを手に取り、幾つか残っているクリップを外すために上部ケースをこじ開けます。
正面パネルボードにアクセスできるように、上部ケースをわずかに持ち上げて少しずらします。
I got confused here. I couldn’t unclip the front panel at all. I found out that if I open the case like a clamshell (or a book, with the front being the spine of the book) I popped right off easily.
Omar Ramos - 返信
Yeah, I saw your comment afterwards but this is exactly what I ended up doing as well. just a note for anyone reading this be careful of the flex cable as it does seem to put a questionable amount of strain on it when you open it in this manner.
ピンセットで青いプラスチックのループを持ち上げて、基板上の白いコネクタにかぶせます。
スパッジャーの先端で、コネクタのロックタブをケーブル側に押し出して、ラッチを解除します。
Or anyone else who has this problem or reads this on this thread, which is not the correct thread for this question by the way, here is a link to the forum for that. It could be any of a number of issues including overheating, Portland elation, or infestation, among others.
Is there somewhere that I can buy a replacement zif connector
ピンセットを使って、基板上のコネクターからケーブルの接続をまっすぐ引き上げます。
上部ケースから取り出します。
Xbox正面のフロントパネルを持ちます。
ピンセットを使ってZIFソケットの中のフロントボタンのケーブルを交換します。
スパッジャーの平面側先端を使って、ケーブルを固定するためにZIFロックを左側に押し込みます。
My Xbox stopped working after this thanks
Mine did as well, its possible it may be the same reason. For me I had to unplug and plug it back in a few times and then clean off the contacts with isopropyl alcohol. Seems simple but if you haven’t already, I would try it.
45度の角度で正面パネルを差し込み、底ケースに付けられたプラスチックのフックに留めてください。
郵便箱を閉める様な手順で、フロントパネルの上部をXboxに押し込みます。強く押し込むと、クリップが正面パネルと上部ケースにロックして、しっかりと固定できます。
正面パネルの基板からスピーカーケーブルのコネクターの接続を外すため、ゆっくりと引き抜きます。
スパッジャーの平面側先端を使って、アンテナケーブルを正面パネルの基板から接続を外します。
If this connector is broken off, will that prevent the control panel to not work at all and NOT turn on? Is there a fix or work around IF this connector is broken off?
Michael Eh - 返信
9.5 mm T9 トルクスネジをWiFi基板から2本外します。
上部メタルケース上のソケットからWiFi基板をまっすぐに持ち上げます。
WiFi基板のアンテナケーブルを残したまま、WiFi基板を動かして、基板下に埋め込まれた"C3"とラベルが貼られたネジを確認します。
When reassembling- put the outer ones on first to secure the port to the metal. Then putting the wi-fi board into the port will be easy
Nate Ennis - 返信
The T9 fit but was a tad big, for me the T8 worked fine
Where can i get a T9
上部メタルケースの上側から65 mm トルクスT10 ネジを8本外します。
マザーボードからハードドライブSATA電源とデータケーブルの接続を外します。
I found that it is not necessary to take out the hard drive in order to remove the front panel module. If you can lift the whole metal enclosure a little to get to the right most torx screw, then you do not need to move the hard drive.
Thanks for letting us know about when the open day is going to be. Will make sure get my work completed by rushmyessay before the day so I can attend it in peace.
光学ドライブの電源とSATAデータケーブルをマザーボードから接続を外します。
I their a way to replace the motherboard pins the piece that connects to the hard drive, part on the motherboard that connects to HD
マザーボードからファンケーブルの接続を外します。
What happens if you pull the pins out of the white piece in accident?
There are some locks on this connector for me. I had to use a straight pin from a cork board to press them in as a gently rocked the connector back and forth to remove this.
Jared Zier - 返信
デバイスを再組み立てする際は、これらのインストラクションを逆の順番に従って作業を進めてください。
80 の人々がこのガイドを完成させました。
以下の翻訳者の皆さんにお礼を申し上げます:
100%
翻訳を始める ›
15 件のコメント
As a device repair tech of a 3rd party store, I have found this be quite easy and profitable for my store to make money. Thanks to these guides, I can now start working on video game consoles.
My fan is making a weird clicking noise everytime I turn on my Xbox One. Does anyone know how to fix this.
I have a quick question so after I remove the fan then what I do
I completely resolved my question when I read this post, thanks to the author for the detailed description. I wrote my review on the https://essaysservicesreviews.com/, you can go in and read. Thank you very much for your attention in your time.
Retrogress - 返信
What happens when one of the plastic clips on the fan breaks. Can the console still run properly or no?
Hi Jayden, the console should still run properly, but the fan won’t sit as secure against the heat sink as it should be. This might not make any difference at all, or the fan might vibrate because it’s not quite as sturdy.
puedo usar Cualquier ventilador O debe Ser un Ventilador especifico
I purchased this new fan for a Xbox One. I received an XBox fan labeled for XBox S Fan - New. The part had one clip broken and was obviously not new from the dirt covering it. Very unsatisfied with this product.
These instructions were perfect. Made an intimidating job easy to follow and complete. I had a working fan back in my Xbox in about an hour. Thanks to the author of this guide and thanks to the guys who made this website for such an incredible resource.
Nice post, <a href="https://paperwritingservices.reviews/buy... rel="nofollow">paperwritingservices.reviews</a>
不同的Report代写 https://www.lxws.net/particular.php?id=1... 机构提供的服务不同,比如有些机构只提供润色、修改服务,而有些机构则提供全套Report代写服务。在选择Report代写机构时,一定要看清楚其提供的服务,确保其能够满足自己的需求。
Different report ghostwriting https://www.lxws.net/particular.php?id=1... institutions provide different services, for example, some institutions only provide polishing and modification services, while others provide a full set of Assignment ghostwriting services. When choosing a report agency, it is important to have a clear understanding of the services it provides to ensure that it meets your needs.
In the United States the Magnuson-Moss Warranty Act of 1975 is a Federal Law that states that stickers and clauses are illegal. It says you can open your electronics without voiding the warranty, regardless of what language of that warranty says.
Dustin D'Amour - 返信
Stickers are illegal!?
Brandon -
For anyone concerned, if you apply heat with a blow dryer or heat gun you can carefully remove the sticker without damaging it, making it impossible to know that the sticker was ever removed.
Kelton Stewart - 返信
All the immature comments aside, thank you Dustin for sharing the information.
Wade - 返信
xbox를 열기 위해서 이러한 위조방지 테이프를 자르거나 떼어내야 합니다. 하지만 걱정 마세요. 여러분이 무언가 직접적으로 망가트리지 않는한 ms는 보증을 취소하지 않습니다.
승대/SeungDae 정/Jeong - 返信
