メインコンテンツにスキップ
Xbox Motherboard Replacement
必要な工具と部品
  1. Xbox Motherboard Replacement, Hard Drive: 手順 1、 1の画像 1
    • Make sure your Xbox is safely unplugged and is laying on a flat, stable surface.
  2. Xbox Motherboard Replacement: 手順 2、 1の画像 1
    • Turn the Xbox over to reveal the four rubber feet.
    • Use a metal spudger to pry off the four rubber feet.
  3. Xbox Motherboard Replacement: 手順 3、 2の画像 1 Xbox Motherboard Replacement: 手順 3、 2の画像 2
    • There are 2 more screws hidden under the two labels on the bottom of the case.
    • You can either remove the labels or simply feel for the screw holes through the labels and then cut or punch a hole through them.
  4. Xbox Motherboard Replacement: 手順 4、 1の画像 1
    • Remove the six T20 Torx screws securing the top cover to the bottom cover.
  5. Xbox Motherboard Replacement: 手順 5、 2の画像 1 Xbox Motherboard Replacement: 手順 5、 2の画像 2
    • Once the bottom and top shells are no longer attached, carefully turn the Xbox right-side-up, lift and remove the top cover.
  6. Xbox Motherboard Replacement: 手順 6、 2の画像 1 Xbox Motherboard Replacement: 手順 6、 2の画像 2
    • Remove the three 3 mm T10 screws securing the hard drive to the Xbox.
    • There is one screw on the rear left side of the hard drive that is only visible when the IDE ribbon cable is lifted up. The other two are at the front right and left sides of the hard drive.
    • The screw on the lower left corner of the disk drive is not in the hole that it appears to be in, but rather just closer to the corner.
  7. Xbox Motherboard Replacement: 手順 7、 2の画像 1 Xbox Motherboard Replacement: 手順 7、 2の画像 2
    • Free the hard drive power cable from the carrier for sufficient slack to lift the hard drive out.
    • Lift the plastic hard drive carrier out of the Xbox case.
  8. Xbox Motherboard Replacement: 手順 8、 3の画像 1 Xbox Motherboard Replacement: 手順 8、 3の画像 2 Xbox Motherboard Replacement: 手順 8、 3の画像 3
    • Remove the four 3.4 mm T15 Torx screws from the plastic hard drive carrier (two screws per side).
    • Carefully remove the hard drive from the plastic carrier. Gentle rocking will see the hard drive come out quite easily.
  9. Xbox Motherboard Replacement: 手順 9、 2の画像 1 Xbox Motherboard Replacement: 手順 9、 2の画像 2
    • Pull both the hard drive data ribbon cable and the power cable straight up from the hard drive.
    • They may be firmly seated, so be careful trying to remove them. DO NOT pull the wires as you may damage the cable assembly.
  10. Xbox Motherboard Replacement, Disc Drive: 手順 10、 3の画像 1 Xbox Motherboard Replacement, Disc Drive: 手順 10、 3の画像 2 Xbox Motherboard Replacement, Disc Drive: 手順 10、 3の画像 3
    • Remove the disk drive. It should come right out.
    • Unplug the ribbon cable and yellow cables from back of disk drive.
  11. Xbox Motherboard Replacement: 手順 11、 1の画像 1
    • Pry back the black plastic tabs around the disk drive in order to remove it from its housing. Once removed, set the drive aside.
    • If you are removing the disk drive in order to gain access to the motherboard underneath, you do not need to remove the plastic housing.
  12. Xbox Motherboard Replacement, Power Board: 手順 12、 1の画像 1
    • Unplug the multi-colored power cord from the motherboard. It is in there pretty tightly, so it may take some effort.
  13. Xbox Motherboard Replacement: 手順 13、 2の画像 1 Xbox Motherboard Replacement: 手順 13、 2の画像 2
    • Using T10 Torx screwdriver, remove two 3mm screws from the tan power supply board.
    • Be very careful not to touch the copper coil or capacitors on the power supply.
  14. Xbox Motherboard Replacement: 手順 14、 1の画像 1
    • Remove the power supply and set it aside. It should lift right out.
    • Be very careful not to touch the copper coil or capacitors on the power supply. They may shock you.
  15. Xbox Motherboard Replacement, Motherboard: 手順 15、 2の画像 1 Xbox Motherboard Replacement, Motherboard: 手順 15、 2の画像 2
    • Unplug the bundle of yellow cables as well as the rainbow cord from the motherboard.
  16. Xbox Motherboard Replacement: 手順 16、 2の画像 1 Xbox Motherboard Replacement: 手順 16、 2の画像 2
    • Remove eleven 3mm screws from motherboard, using a T10 Torx screwdriver. Refer to the picture to find all eleven.
    • Unplug the power cable attached to the fan.
  17. Xbox Motherboard Replacement: 手順 17、 1の画像 1
    • Remove the motherboard from the Xbox. As long as all of the screws are out and the fan is disconnected, it will lift out easily.
終わりに
45 の人々がこのガイドを完成させました。
作成者
7人の作成者と共同で作成されました。
rmarstel
メンバー登録日: 10/29/09
6,068 ポイント
5のガイドは作成済み
チーム
Cal Poly, Team 18-2, Maness Fall 2009 Cal Poly, Team 18-2, Maness Fall 2009人のメンバー
CPSU-MANESS-F09S18G2
3 メンバー
26のガイドは作成済み
6件のガイドコメント
http://www.ebay.com/gds/How-To-Determine...
Utilize the information on this website to determine what Xbox version you have so you know what replacement parts to look for.
Navy Vet 2015 - 返信
What about the key lock between the HDD and original motherboard? Wouldn't you get an error message installing a new motherboard?
chris - 返信
Yes, this would result in an error. An exception exists where the owner has modified the console and taken a backup of the EEPROM key.
James J -
If I need a new motherboard where can I find one
nite gang - 返信
Do you still need a motherboard?
Comanche -
コメントを追加
統計データ:
過去 24時間: 20
過去 7 日: 83
過去 30 日: 388
今までの合計 54,745
