この修理ガイドは変更されています。最新の未承認バージョンに切り替えます。
はじめに
This guide will explain how to disassemble the Xbox DVD Drive in order to preform repairs or remove a stuck game by manually ejecting the drive.
必要な工具と部品
Remove the disk drive. It should come right out.
Unplug the ribbon cable and yellow cables from back of disk drive.
Please note that if all you are trying to do is manually eject a game and not make repairs to the drive, step 14 is the ONLY required step. It is NOT necessary to remove the drives casing, just push the tray in when you're done.
Start by removing the 4 screws on the bottom of the drives case using a Philips #0. There are different variations of the drive and some have Torx screws instead of Philips. Use the necessary tool for the specific version that you have.
Once screws are removed, lift the bottom half of the case up and away from the drive.
Flip the drive over and remove the top half of the drives case.
Using your screwdriver, or anything slim enough to fit, gently push the white lever back. Put your object on the right hand side of the lever, slightly pushing right as you push back.
The lens will drop down and your drive door will open about a quarter inch.
Gently pull the tray to its open position. If you have a game stuck in your drive, this would be the ideal time to remove it. It can be removed in step 13 but it's not as easy.
Gently push the tray closed by hand.
Using your screwdriver, or whatever object best suits you, you need to return the white lever to its forward position to reset the drive properly. Get your object behind the right side of the lever, gently pushing it forward, returning it to its original position.
Put the top of the case on first and then flip the drive.
Replace the bottom half of the case and secure the screws back in place.
To reassemble your device, follow these instructions in reverse order STARTING FROM STEP 12.
6 の人々がこのガイドを完成させました。
3 件のコメント
What is the easiest way to clean the laser in the original xbox?
Hit it with a can of air duster. If further cleaning is required apply a small amount of rubbing alcohol on a Q-tip and gently clean the lens. I hope this helps.
