この修理ガイドは変更されています。最新の未承認バージョンに切り替えます。
はじめに
Steady your aim by replacing the analog stick grips on the Xbox 360 wireless controller.
必要な工具と部品
Depress the battery release button on the top of the controller.
Remove the battery holder from the controller.
Use the flat end of a spudger to remove the vibration motor cable, moving it upward from its socket on the logic board.
Lift the vibration motor out of the front case.
Lifting from the headphone jack and power plug, remove the logic board from the front case.
97 の人々がこのガイドを完成させました。
3 件のコメント
unnecessary steps.
3 steps:
remove all 7 screws.
flip upside down remove top plate
pull stick caps off
reinstall in reverse.
you may have to slide the vibration motors into the slots on the top half when putting back together.
