メインコンテンツにスキップ
Xbox 360 Wireless Controller 3D Analog Sensor Replacement
アーカイブされたガイド
このガイドは将来的な使用のためにのみ保存されてます。ご自身の修理作業には更新バージョンをご利用ください。
必要な工具と部品
  1. Xbox 360 Wireless Controller 3D Analog Sensor Replacement, Battery: 手順 1、 2の画像 1 Xbox 360 Wireless Controller 3D Analog Sensor Replacement, Battery: 手順 1、 2の画像 2
    • Depress the battery release button on the top of the controller.
    • Remove the battery holder from the controller.
    • The standard option for Xbox 360 Wireless Controllers Battery Packs is AA batteries. A rechargeable battery is also available, but both battery options are removed from the controller in the same way.
  2. Xbox 360 Wireless Controller 3D Analog Sensor Replacement, Rear Case: 手順 2、 1の画像 1
    この手順で使用する道具:
    購入する
    • Use a pair of tweezers to peel the barcode sticker from the battery compartment.
  3. Xbox 360 Wireless Controller 3D Analog Sensor Replacement: 手順 3、 1の画像 1
    • Remove the seven 9.3 mm T8 Security Torx screws securing the rear case to the front case.
  4. Xbox 360 Wireless Controller 3D Analog Sensor Replacement: 手順 4、 2の画像 1 Xbox 360 Wireless Controller 3D Analog Sensor Replacement: 手順 4、 2の画像 2
    この手順で使用する道具:
    Spudger
    $2.99
    購入する
    • Insert a Spudger between the front and rear cases along the left edge of the controller.
    • Rotate the spudger toward the front of the controller, prying the two cases apart.
  5. Xbox 360 Wireless Controller 3D Analog Sensor Replacement: 手順 5、 2の画像 1 Xbox 360 Wireless Controller 3D Analog Sensor Replacement: 手順 5、 2の画像 2
    • Insert a spudger between the front and rear cases, near the headphone jack.
    • Rotate the spudger toward the front of the controller to pry the two cases apart.
  6. Xbox 360 Wireless Controller 3D Analog Sensor Replacement: 手順 6、 2の画像 1 Xbox 360 Wireless Controller 3D Analog Sensor Replacement: 手順 6、 2の画像 2
    • Grasp the controller by the battery compartment and the headphone jack.
    • Lift the battery compartment away from the headphone jack, separating the rear case from the front case and logic board.
    • The battery contact springs are held in place by slots in the battery housing in the rear case. Be sure to realign them properly during reassembly.
  7. Xbox 360 Wireless Controller 3D Analog Sensor Replacement, Vibration Motors: 手順 7、 2の画像 1 Xbox 360 Wireless Controller 3D Analog Sensor Replacement, Vibration Motors: 手順 7、 2の画像 2
    • Use the flat end of a spudger to remove the vibration motor cable, moving it upward from its socket on the logic board.
    • Lift the vibration motor out of the front case.
  8. Xbox 360 Wireless Controller 3D Analog Sensor Replacement: 手順 8、 2の画像 1 Xbox 360 Wireless Controller 3D Analog Sensor Replacement: 手順 8、 2の画像 2
    • Remove the vibration motor from the other side of the controller using the same method previously described.
    • The left motor has significantly more counterweight than the right motor.
  9. Xbox 360 Wireless Controller 3D Analog Sensor Replacement, Logic Board: 手順 9、 2の画像 1 Xbox 360 Wireless Controller 3D Analog Sensor Replacement, Logic Board: 手順 9、 2の画像 2
    • Lifting from the headphone jack and power plug, remove the logic board from the front case.
  10. Xbox 360 Wireless Controller 3D Analog Sensor Replacement, Triggers: 手順 10、 3の画像 1 Xbox 360 Wireless Controller 3D Analog Sensor Replacement, Triggers: 手順 10、 3の画像 2 Xbox 360 Wireless Controller 3D Analog Sensor Replacement, Triggers: 手順 10、 3の画像 3
    • Using your thumb and forefinger, push the left trigger toward the right side of the controller. Simultaneously push the trigger control arm in the opposite direction.
    • The trigger has a peg that fits into a slot in the trigger arm. Be sure to push far enough so that the peg clears the slot.
    • Push the trigger arm downward.
  11. Xbox 360 Wireless Controller 3D Analog Sensor Replacement: 手順 11、 3の画像 1 Xbox 360 Wireless Controller 3D Analog Sensor Replacement: 手順 11、 3の画像 2 Xbox 360 Wireless Controller 3D Analog Sensor Replacement: 手順 11、 3の画像 3
    • Insert the edge of a spudger in between the trigger and the trigger assembly near the left edge. Pry the housing away from the catch on the trigger.
    • Using the previously described technique, pry the housing on the right edge away from the trigger.
    • Rotate the trigger away from the logic board, past its housing.
  12. Xbox 360 Wireless Controller 3D Analog Sensor Replacement: 手順 12、 3の画像 1 Xbox 360 Wireless Controller 3D Analog Sensor Replacement: 手順 12、 3の画像 2 Xbox 360 Wireless Controller 3D Analog Sensor Replacement: 手順 12、 3の画像 3
    • Using a spudger, pry the trigger spring off its peg on the trigger housing.
    • Pull the trigger spring out of the trigger.
  13. Xbox 360 Wireless Controller 3D Analog Sensor Replacement: 手順 13、 3の画像 1 Xbox 360 Wireless Controller 3D Analog Sensor Replacement: 手順 13、 3の画像 2 Xbox 360 Wireless Controller 3D Analog Sensor Replacement: 手順 13、 3の画像 3
    • Slide the trigger toward the right side of the logic board, and rotate it clockwise.
    • Remove the right trigger from the logic board.
    • To remove the left trigger from the logic board, follow the procedure previously described for the right trigger.
    • To remove the trigger control, only one has to be removed as it is over the analog sensor (left side).
    • Optional: It is easier to remove both, so as to avoid burning or melting the plastic while working.
    • The part should easily slide out once the solder is properly removed. If not, go back and check for solder left in the joints.
    • Heat and suck up the solder.
    • Remove analog sensor and place new part.
    • Hold part in place and make a quick solder to hold it up in place.
    • Now solder all joints and follow in reverse.
終わりに
ある他の人がこのガイドを完成しました。
作成者
9人の作成者と共同で作成されました。
_Z_
メンバー登録日: 03/18/12
9,668 ポイント
2のガイドは作成済み
チーム
Master Techs Master Techs人のメンバー
Community
321 メンバー
1,468のガイドは作成済み
コメント 1 件
this guide will be finished as soon as i have time.
_Z_ - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 15
今までの合計 2,631
