この分解は修理ガイドでは ありません 。 お持ちのXbox 360を修理する際は、iFixitの修理ガイド をご利用ください。
Use a small tool to stick in and push these pins
Be sure to keep pressure pulling outwards for this to come out easily
Make sure that you pop out the pins on both sides
You have to evenly disconnect all four of these connectors holding it together
I used flat head screw driver bits to hold the connectors open
You have to remove a warranty sticker to open the console. Be warned, this will void your warranty.
You must push in these buttons (7 in total)
It is nearly impossible to not mess up the plastic using a screwdriver, i would recommend using an x-acto knife
This was one of the harder steps, you must push the button in until it clicks and then go farther still
Make sure you keep pressure applied outwards so that the locks do not re-engage
Remove the six silver screws
Flip over the whole Xbox holding both the plastic and the metal, then pull off the casing
Carefully remove the two connectors
The disc drive may have some tape in the front holding it in place, simply remove this.
このガイドを埋め込む
サイズを選択し、以下のコードをコピーして、このガイドを小さなウィジェットとしてサイト/フォーラムに埋め込みます。
1つの手順
全ガイド
小サイズ - 600px
中サイズ - 800px
大サイズ - 1200px
プレビュー
