はじめに
左側のケースを交換して、Xbox 360 Sをピカピカにしましょう。
必要な工具と部品
このデバイスを再組み立てするには、インストラクションを逆の順番に従って作業を進めてください。
26 の人々がこのガイドを完成させました。
以下の翻訳者の皆さんにお礼を申し上げます:
100%
翻訳を始める ›
2 件のコメント
Prying the top and bottom case apart with a metal spudger?, you'll ruin your xbox 360 slim case....your already voiding your warrenty, why not open it the right way??, their's is a pin-hole located at the back where the sticker is, just stick a pin into it and it will release that clip thats holding it together!
if you are going to do something like open your xbox360, do it right the first time.......
ATTENTION: The metal spudger is absolutely wrong for that second tab, you will never reach it. Instead, place your thumb over where the security sticker is on the top half of the case and apply pressure, the tab will snap out of place with the right amount of gradual force. This drove me nuts for an hour and I found the solution elsewhere.
