メインコンテンツにスキップ
Xbox 360 S Faceplate Replacement
必要な工具と部品
  1. Xbox 360 S Faceplate Replacement, Top Panel: 手順 1、 1の画像 1
    • In the following steps, you will remove the top vent, secured to the top panel by the thirteen clips shown.
    • Take care when removing the fan vent not to break any of the plastic clips.
  2. Xbox 360 S Faceplate Replacement: 手順 2、 2の画像 1 Xbox 360 S Faceplate Replacement: 手順 2、 2の画像 2
    • Orient the console so that the words "XBOX 360" on the sides are right-side up, and the faceplate is facing to the left.
    • Insert a metal spudger between the top vent and the top bezel near the rear of the Xbox.
    • Rotate the spudger away from the console, prying the edge of the fan vent up until the two plastic clips come free.
    • Be sure to rotate the spudger far enough so that the plastic clips clear the silver rim of the top bezel.
  3. Xbox 360 S Faceplate Replacement: 手順 3、 3の画像 1 Xbox 360 S Faceplate Replacement: 手順 3、 3の画像 2 Xbox 360 S Faceplate Replacement: 手順 3、 3の画像 3
    • Insert a metal spudger between the fan vent and top bezel along the left side of the console.
    • In the same manner described above, begin prying the left side of the top vent away from the top bezel.
    • Continue prying along the left side of the device, freeing all the clips on that side.
  4. Xbox 360 S Faceplate Replacement: 手順 4、 2の画像 1 Xbox 360 S Faceplate Replacement: 手順 4、 2の画像 2
    • Lift the fan vent up from the freed left side to disengage the clips along the right side.
    • Remove the entire fan vent.
  5. Xbox 360 S Faceplate Replacement: 手順 5、 2の画像 1 Xbox 360 S Faceplate Replacement: 手順 5、 2の画像 2
    • In the following steps, you will be releasing the six clips highlighted in red.
    • Each clip can be undone by inserting a metal spudger underneath the bottom edge of the clip. Once underneath the bottom edge, simply prying away from the console will free the clip.
  6. Xbox 360 S Faceplate Replacement: 手順 6、 2の画像 1 Xbox 360 S Faceplate Replacement: 手順 6、 2の画像 2
    • Orient the console so that the left case is facing toward you and the faceplate is facing toward the right.
    • Insert a metal spudger through the front-most slit on the left edge of the top bezel and between the bottom edge of the clip and the left case, as described above.
    • Simultaneously rotate the spudger away from the console and pull up on the top bezel to free the clip.
    • You will hear a "pop" signifying that the clip cleared its catch.
  7. Xbox 360 S Faceplate Replacement: 手順 7、 2の画像 1 Xbox 360 S Faceplate Replacement: 手順 7、 2の画像 2
    • Using the same method described above, free the two remaining clips along the left edge of the top bezel.
  8. Xbox 360 S Faceplate Replacement: 手順 8、 1の画像 1
    • Grab the entire top panel with your hands, lift up the entire left edge high enough to rest the separated clips on top of the left case.
    • You may have to go back with a spudger and undo any clips that have re-attached.
    • The top panel will not come free of the console yet.
  9. Xbox 360 S Faceplate Replacement: 手順 9、 2の画像 1 Xbox 360 S Faceplate Replacement: 手順 9、 2の画像 2
    • Rotate the console so that the rear of the Xbox 360 S is facing to the right, and the right case is facing you.
    • Insert a metal spudger through the rear-most slit on the right edge of the top bezel and between the bottom edge of the clip and the right case.
    • While lifting up on the top bezel with your fingers, rotate the spudger away from the console to free the clip.
  10. Xbox 360 S Faceplate Replacement: 手順 10、 2の画像 1 Xbox 360 S Faceplate Replacement: 手順 10、 2の画像 2
    • In the same manner as described in the previous steps, release the middle and front clips along the right edge of the top panel.
  11. Xbox 360 S Faceplate Replacement: 手順 11、 1の画像 1
    • Lift the top panel off the device.
    • You may have to go back with a spudger and undo any clips that have re-attached to the console.
  12. Xbox 360 S Faceplate Replacement, Hard Drive: 手順 12、 3の画像 1 Xbox 360 S Faceplate Replacement, Hard Drive: 手順 12、 3の画像 2 Xbox 360 S Faceplate Replacement, Hard Drive: 手順 12、 3の画像 3
    • Orient the Xbox 360 S so that the bottom of the console is facing toward you.
    • Push the latch holding down the hard drive cover to the left.
    • Pull the hard drive cover away from the console.
  13. Xbox 360 S Faceplate Replacement: 手順 13、 3の画像 1 Xbox 360 S Faceplate Replacement: 手順 13、 3の画像 2 Xbox 360 S Faceplate Replacement: 手順 13、 3の画像 3
    • Firmly grasp the fabric tab labeled with the size of the hard drive (e.g. "250 GB") attached to the hard drive.
    • Pull the hard drive straight out of the console.
    • The fabric tab is attached to a catch further inside the hard drive housing. It will take some force to pull the hard drive out.
  14. Xbox 360 S Faceplate Replacement, Bottom Panel: 手順 14、 1の画像 1
    • In the following steps, you will remove the bottom vent.
    • It is attached to the bottom panel by the seven clips shown.
  15. Xbox 360 S Faceplate Replacement: 手順 15、 2の画像 1 Xbox 360 S Faceplate Replacement: 手順 15、 2の画像 2
    • Orient the Xbox 360 S so that the hard drive port is facing up and the faceplate is facing to the left.
    • Insert a metal spudger between the black bottom vent and the silver rim of the bottom bezel, in the rear right corner of the vent.
    • Rotate the spudger away from the console, prying the vent up from the bottom bezel.
    • Be sure to rotate the spudger far enough so that the clips on the vent are lifted past the silver rim of the bottom bezel.
  16. Xbox 360 S Faceplate Replacement: 手順 16、 3の画像 1 Xbox 360 S Faceplate Replacement: 手順 16、 3の画像 2 Xbox 360 S Faceplate Replacement: 手順 16、 3の画像 3
    • In the same manner as described above, pry the two remaining clips on the bottom right edge.
    • All of the clips along both the right and front edge should now be free. If other clips have come undone as well, that is fine.
  17. Xbox 360 S Faceplate Replacement: 手順 17、 2の画像 1 Xbox 360 S Faceplate Replacement: 手順 17、 2の画像 2
    • Remove the bottom vent by lifting it away from the bottom bezel.
  18. Xbox 360 S Faceplate Replacement: 手順 18、 2の画像 1 Xbox 360 S Faceplate Replacement: 手順 18、 2の画像 2
    • In the following steps, you will remove the bottom bezel, which is attached to the rest of the console by the six clips shown.
    • The clips shown in red can be detached by inserting a metal spudger underneath the bottom edge of the clip. Once underneath the bottom edge, simply prying away from the console will free the clip.
  19. Xbox 360 S Faceplate Replacement: 手順 19、 2の画像 1 Xbox 360 S Faceplate Replacement: 手順 19、 2の画像 2
    • Insert a metal spudger through the slit near the rear left corner of the bottom bezel.
    • Rotate the spudger away from the device while lifting the rear bezel up with the other hand.
    • You may hear a "pop" signifying the clip has cleared its catch.
  20. Xbox 360 S Faceplate Replacement: 手順 20、 2の画像 1 Xbox 360 S Faceplate Replacement: 手順 20、 2の画像 2
    • Insert a metal spudger through the left middle slit of the bottom bezel, and between the bottom edge of the clip and the left case.
    • Simultaneously pull the bottom bezel up and rotate the spudger away from the console to free the clip.
    • In a similar fashion, free the clip at the front of the bottom bezel's left edge.
    • The entire left side of the bottom bezel should now be free.
  21. Xbox 360 S Faceplate Replacement: 手順 21、 2の画像 1 Xbox 360 S Faceplate Replacement: 手順 21、 2の画像 2
    • Turn the console around so that the faceplate is facing to the right and the right case is facing toward you.
    • Insert the spudger into the rear-most slit on the right edge of the bottom bezel, and wedge it behind the clip by pushing the spudger down while pushing the tip of the spudger against the right case.
    • Simultaneously release the clip and pull the bottom bezel up.
    • This clip is especially hard to remove. Some force will be required to insert the spudger correctly.
  22. Xbox 360 S Faceplate Replacement: 手順 22、 1の画像 1
    • This clip does not have a slit in the bezel to guide you. You can locate the clip by looking under the bezel near the hard drive slot.
    • Insert a spudger between the silver rim and bottom bezel directly above the clip shown.
    • Release the clip while pulling up on the bottom bezel.
  23. Xbox 360 S Faceplate Replacement: 手順 23、 2の画像 1 Xbox 360 S Faceplate Replacement: 手順 23、 2の画像 2
    • This clip is smaller than the others and should not be removed from above like the others.
    • Lift the left edge of the bottom bezel up enough to gain clearance.
    • Insert a metal spudger behind the left edge of the last clip, and push the clip away from the right case.
  24. Xbox 360 S Faceplate Replacement, Left Case: 手順 24、 1の画像 1
    • Opening your Xbox 360 any further will require breaking or removing the warranty sticker on the outer case. Your Microsoft warranty for any components not directly attached to the logic board will likely be voided by removing this seal.
  25. Xbox 360 S Faceplate Replacement: 手順 25、 2の画像 1 Xbox 360 S Faceplate Replacement: 手順 25、 2の画像 2
    • Orient the console right-side up, with the faceplate facing toward you.
    • Locate the two clips connecting the right and left case along the top edge of the console, behind the Wi-Fi card.
    • While pushing the left and right case away from each other with one hand, pry the clips away from the case with a metal spudger.
  26. Xbox 360 S Faceplate Replacement: 手順 26、 2の画像 1 Xbox 360 S Faceplate Replacement: 手順 26、 2の画像 2
    • Continue to hold the two cases apart to prevent the clips reattaching.
    • Insert a spudger between the right and left cases to hold them separate while you work elsewhere.
  27. Xbox 360 S Faceplate Replacement: 手順 27、 2の画像 1 Xbox 360 S Faceplate Replacement: 手順 27、 2の画像 2
    • Flip the Xbox over so the faceplate is facing left, and the left case is facing toward you.
    • While pushing the left and right cases apart with one hand, free one clip located beside the hard drive slot.
  28. Xbox 360 S Faceplate Replacement: 手順 28、 2の画像 1 Xbox 360 S Faceplate Replacement: 手順 28、 2の画像 2
    • Continue to hold the cases apart to prevent the clips from reattaching.
    • Place another spudger between the left and right cases directly below the clip.
  29. Xbox 360 S Faceplate Replacement: 手順 29、 3の画像 1 Xbox 360 S Faceplate Replacement: 手順 29、 3の画像 2 Xbox 360 S Faceplate Replacement: 手順 29、 3の画像 3
    • Insert the flat edge of a metal spudger between the left and right cases where the warranty sticker used to be.
    • Pry the left case upwards to form a gap between the two cases, and slide the spudger in toward the left case.
    • Rotate the spudger upward to release the last clip.
    • The spudgers holding the top and bottom clips apart may be removed.
  30. Xbox 360 S Faceplate Replacement: 手順 30、 2の画像 1 Xbox 360 S Faceplate Replacement: 手順 30、 2の画像 2
    • Release one clip in the front left corner of the top edge securing the left case to the faceplate.
  31. Xbox 360 S Faceplate Replacement: 手順 31、 2の画像 1 Xbox 360 S Faceplate Replacement: 手順 31、 2の画像 2
    • Flip the console over so the bottom is facing upward.
    • Release one clip in the front left corner of the bottom edge securing the left case to the faceplate.
    • Rotate the left case away from the device to release the last two inner clips.
    • Remove the left case.
  32. Xbox 360 S Faceplate Replacement, Faceplate: 手順 32、 2の画像 1 Xbox 360 S Faceplate Replacement, Faceplate: 手順 32、 2の画像 2
    • Orient the console right-side-up, with the faceplate facing forward.
    • Release the clip near the front right corner of the top edge securing the right case to the faceplate.
  33. Xbox 360 S Faceplate Replacement: 手順 33、 1の画像 1
    • Turn the console over, so that the bottom is facing upward, and the faceplate is facing forward.
    • Release the clip in the bottom right corner of the top edge securing the right case to the front case.
  34. Xbox 360 S Faceplate Replacement: 手順 34、 2の画像 1 Xbox 360 S Faceplate Replacement: 手順 34、 2の画像 2
    • Lift the left edge of the faceplate upward to release the last two clips securing the faceplate to the right case.
    • Detach the faceplate from the rest of the device.
    • The faceplate is still attached to the console by a thin ribbon cable. Do not attempt to completely remove the faceplate yet.
  35. Xbox 360 S Faceplate Replacement: 手順 35、 3の画像 1 Xbox 360 S Faceplate Replacement: 手順 35、 3の画像 2 Xbox 360 S Faceplate Replacement: 手順 35、 3の画像 3
    • Using a spudger or fingernail, lift the clear blue tab away from the connector.
    • Slide the locking tab on the power switch board cable connector toward the top of the console.
    • The locking tab will only move about 2 mm.
    • Pull the power switch cable straight out of the connector.
    • The faceplate is now free of the rest of the console.
終わりに
44 の人々がこのガイドを完成させました。
作成者
6人の作成者と共同で作成されました。
Matthew Newsom
メンバー登録日: 01/05/10
39,500 ポイント
67のガイドは作成済み
4 件のコメント
Thank you to who ever posted this! The directions are clear, you just have to read than reread, go slowly and don't force anything and most importantly do not get frustrated. My grandpa always said "if it is worth doing, do it right the first time.", and "measure twice, cut once."
Dylan Howe - 返信
so true. :) I needed this guide to replace my Xbox 1 S shell because I got frustrated when taking apart the original.
me I -
Thanks for your . Step by step instructions .. Knowledge is worth sharing...
vk7474 - 返信
Care is required from Step 5. Do not slide the spludger down the back of the faceplate. This may (it did) damage the ribbon to the power and eject button on the front plate. OOPS.
Stephen - 返信
コメントを追加
統計データ:
過去 24時間: 7
過去 7 日: 61
過去 30 日: 246
今までの合計 71,135
