はじめに
Use this guide to replace the RF module in your Xbox 360 E.
必要な工具と部品
Push the Spudger into the crevice between the grated top panel of the Xbox and the bottom body with the rubber feet.
Pull back on the spudger like a lever, keeping it pressed firmly into the crevice.
Push the spudger into the crevice between the right grated face and the top body of the Xbox. It's easier to begin away from the vent.
Pull up on the spudger like a lever, keeping it pressed firmly into the crevice.
In front of the CD drive you will find the Xbox logo. Press on the area left of the Xbox logo, and the disk tray panel will pop off.
Keep holding the partially separated panel open. It's easiest to do this by wedging a spudger into the opening but can also be held open by your hands.
Rotate the Xbox to the left to locate the clip connecting the front panel to the body. Insert the spudger inside the gap to release the clip. This may require wiggling the spudger. The clip will pop off, making the front panel looser.
Looking at the body of the device, locate the green panel to the right of the CD drive.
Remove the two 6 mm screws located on the top left and middle right with a T8 Torx screwdriver.
Grip the middle of the green board and gently pull it out.
6 の人々がこのガイドを完成させました。
2件のガイドコメント
Were can I buy an RF module?
