メインコンテンツにスキップ
Xbox 360 E Front Panel Replacement
必要な工具と部品
  1. Xbox 360 E Front Panel Replacement, Front Panel: 手順 1、 3の画像 1 Xbox 360 E Front Panel Replacement, Front Panel: 手順 1、 3の画像 2 Xbox 360 E Front Panel Replacement, Front Panel: 手順 1、 3の画像 3
    • In front of the CD drive you will find the Xbox logo. Press on the area left of the Xbox logo, and the disk tray panel will pop off.
  2. Xbox 360 E Front Panel Replacement: 手順 2、 3の画像 1 Xbox 360 E Front Panel Replacement: 手順 2、 3の画像 2 Xbox 360 E Front Panel Replacement: 手順 2、 3の画像 3
    • Beginning on the left side without the grate, run the spudger along the crevice until you've reached the grated part, while holding the part that's being separated as you go.
  3. Xbox 360 E Front Panel Replacement: 手順 3、 3の画像 1 Xbox 360 E Front Panel Replacement: 手順 3、 3の画像 2 Xbox 360 E Front Panel Replacement: 手順 3、 3の画像 3
    • Keep holding the partially separated panel open. It's easiest to do this by wedging a spudger into the opening but can also be held open by your hands.
    • Rotate the Xbox to the left to locate the clip connecting the front panel to the body. Insert the spudger inside the gap to release the clip. This may require wiggling the spudger. The clip will pop off, making the front panel looser.
  4. Xbox 360 E Front Panel Replacement: 手順 4、 3の画像 1 Xbox 360 E Front Panel Replacement: 手順 4、 3の画像 2 Xbox 360 E Front Panel Replacement: 手順 4、 3の画像 3
    • Flip the Xbox so the opposite side is towards you. Make sure to keep the separation open.
    • Locate the other clip and insert the spudger to remove it.
  5. Xbox 360 E Front Panel Replacement: 手順 5、 2の画像 1 Xbox 360 E Front Panel Replacement: 手順 5、 2の画像 2
    • Continue to run the spudger along the crease to release any further clips that may still be attatched.
    • Do no pull off the panel too fast because you don't want to damage the ribbon cable. Slowly pull away the panel.
    • Now that the front panel has been released from its clips you can pull off the front panel.
  6. Xbox 360 E Front Panel Replacement: 手順 6、 3の画像 1 Xbox 360 E Front Panel Replacement: 手順 6、 3の画像 2 Xbox 360 E Front Panel Replacement: 手順 6、 3の画像 3
    • Find the brown section where the ribbon cable enters the green board. Flip the brown part up and pull out the plastic tab at the end of the ribbon.
終わりに
6 の人々がこのガイドを完成させました。
作成者
4人の作成者と共同で作成されました。
Sarah
メンバー登録日: 01/30/14
1,732 ポイント
4のガイドは作成済み
チーム
Cal Poly, Team 2-11, Amido Winter 2014 Cal Poly, Team 2-11, Amido Winter 2014人のメンバー
CPSU-AMIDO-W14S2G11
4 メンバー
43のガイドは作成済み
コメント 1 件
Where can I find a new ribbon cable for Xbox 360 e? In addition, can very minuscule damage to cable cause the power button to turn red?
braxton.taylor25 - 返信
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 11
過去 30 日: 57
今までの合計 5,874
