メインコンテンツにスキップ
Xbox 360 Controller Shell & Thumbstick Replacement
必要な工具と部品
  1. Xbox 360 Controller Shell & Thumbstick Replacement, Ensuring Safety: 手順 1、 1の画像 1
    • Remove all batteries or power sources from remote.
    • This is to ensure that there are no electric currents traveling through the remote, ensuring you will not be shocked.
    • This is very important.
  2. Xbox 360 Controller Shell & Thumbstick Replacement, Replacing the Shell: 手順 2、 1の画像 1
    • Using a TP Torx T8 Screwdriver, remove all 6 screws from the back of your controller.
    • Keep the screws in a safe place to ensure you will not lose them.
  3. Xbox 360 Controller Shell & Thumbstick Replacement, Replacing the Shell: 手順 3、 2の画像 1 Xbox 360 Controller Shell & Thumbstick Replacement, Replacing the Shell: 手順 3、 2の画像 2
    • Remove barcode sticker from back wall of battery port.
    • Remove hidden screw from location of sticker with the same TP Torx T8 Screwdriver.
  4. Xbox 360 Controller Shell & Thumbstick Replacement, Replacing the Shell: 手順 4、 2の画像 1 Xbox 360 Controller Shell & Thumbstick Replacement, Replacing the Shell: 手順 4、 2の画像 2
    • Pry open the controller. Optionally, gently push in the thumbstick to eject the back half. (Some buttons may fall out.)
    • This will leave you with 2 separate pieces. Disconnect rumble motors, using fingers on sides of connectors.
  5. Xbox 360 Controller Shell & Thumbstick Replacement, Replacing the Shell: 手順 5、 1の画像 1
    • To remove bumper housing and bottom piece, pull away from the shell (along the axis of the screwposts).
  6. Xbox 360 Controller Shell & Thumbstick Replacement, Replacing the Shell: 手順 6、 2の画像 1 Xbox 360 Controller Shell & Thumbstick Replacement, Replacing the Shell: 手順 6、 2の画像 2
    • Remove all mesh and buttons from controller, as well as the motherboard.
    • Remember to keep small parts in a safe place to prevent the loss of a part.
    • Later photo will clarify which button goes in which hole.
  7. Xbox 360 Controller Shell & Thumbstick Replacement, Replacing the Shell: 手順 7、 2の画像 1 Xbox 360 Controller Shell & Thumbstick Replacement, Replacing the Shell: 手順 7、 2の画像 2
    • To remove arrow keys, locate the screws hidden within the key.
    • Using 1.5 crosshead screwdriver, remove these screws and "store them in a safe place."
  8. Xbox 360 Controller Shell & Thumbstick Replacement, Cleaning the Controller: 手順 8、 1の画像 1
    • Clean shells and buttons with rubbing alcohol if needed.
    • Do not consume rubbing alcohol.
  9. Xbox 360 Controller Shell & Thumbstick Replacement, Reassembly: 手順 9、 2の画像 1 Xbox 360 Controller Shell & Thumbstick Replacement, Reassembly: 手順 9、 2の画像 2
    • Insert buttons into new shell as pictured.
    • Place mesh back onto buttons.
  10. Xbox 360 Controller Shell & Thumbstick Replacement, Reassembly: 手順 10、 3の画像 1 Xbox 360 Controller Shell & Thumbstick Replacement, Reassembly: 手順 10、 3の画像 2 Xbox 360 Controller Shell & Thumbstick Replacement, Reassembly: 手順 10、 3の画像 3
    • Snap arrow keys into hole.
    • Replace the screws and place mesh over keys.
  11. Xbox 360 Controller Shell & Thumbstick Replacement, Reassembly: 手順 11、 3の画像 1 Xbox 360 Controller Shell & Thumbstick Replacement, Reassembly: 手順 11、 3の画像 2 Xbox 360 Controller Shell & Thumbstick Replacement, Reassembly: 手順 11、 3の画像 3
    • Place the triggers and the motherboard in their respective places.
    • Re-attach rumble motors. Note orientation of T-slot in connector.
  12. Xbox 360 Controller Shell & Thumbstick Replacement, Reassembly: 手順 12、 2の画像 1 Xbox 360 Controller Shell & Thumbstick Replacement, Reassembly: 手順 12、 2の画像 2
    • Close controller and replace the screws with the TP Torx T8 Screwdriver.
  13. Xbox 360 Controller Shell & Thumbstick Replacement, Replacing Thumbstick: 手順 13、 3の画像 1 Xbox 360 Controller Shell & Thumbstick Replacement, Replacing Thumbstick: 手順 13、 3の画像 2 Xbox 360 Controller Shell & Thumbstick Replacement, Replacing Thumbstick: 手順 13、 3の画像 3
    • Complete steps 1-4 on the controller with the faulty thumbstick.
  14. Xbox 360 Controller Shell & Thumbstick Replacement, Replacing Thumbstick: 手順 14、 3の画像 1 Xbox 360 Controller Shell & Thumbstick Replacement, Replacing Thumbstick: 手順 14、 3の画像 2 Xbox 360 Controller Shell & Thumbstick Replacement, Replacing Thumbstick: 手順 14、 3の画像 3
    • To remove thumbstick, pull the thumbstick vertically off of its base.
    • Place the new thumbstick onto its base, pushing it down as far as possible without breaking the base.
    • If you have purchased the wrong style of thumbstick, superglue, hot glue, or any other adhesive should work fine. Simply use a needle to put some adhesive and/or glue into the hole.
  15. Xbox 360 Controller Shell & Thumbstick Replacement, Replacing Thumbstick: 手順 15、 3の画像 1 Xbox 360 Controller Shell & Thumbstick Replacement, Replacing Thumbstick: 手順 15、 3の画像 2 Xbox 360 Controller Shell & Thumbstick Replacement, Replacing Thumbstick: 手順 15、 3の画像 3
    • Once your thumbstick is in place, complete steps 9-12 to reassemble.
終わりに
You have successfully replaced the shell, and thumbstick, on your Xbox 360 Controller, congratulations!
12 の人々がこのガイドを完成させました。
作成者
4人の作成者と共同で作成されました。
victoriabethhopkins
メンバー登録日: 06/05/15
381 ポイント
1ガイドが承認済み
2件のガイドコメント
Ok, so I did this exactly as shown but now my controller doesn't work. I'm an fps player and I need to aim down sights but the left trigger doesn't work. But when I open up my menu (Xbox guide) it won't stop aiming down sights even though I'm not touching the trigger at all. It works perfectly fine on everything else like the guide or Netflix but doesn't work for things like destiny or battlefield 4. And yes it worked before and everything else works. If you can help please do. Cause I spent around $40 on everything
Ethan Schaffer - 返信
"Security" Torx T8 is necessary, since the screw heads have center pins.
Michael Folsom - 返信
コメントを追加
統計データ:
過去 24時間: 6
過去 7 日: 33
過去 30 日: 112
今までの合計 13,096
