メインコンテンツにスキップ
XPS M2010 MXP061 Memory Module Replacement
必要な工具と部品
  1. XPS M2010 MXP061 Memory Module Replacement, Memory Cover Remove: 手順 1、 1の画像 1
    • CAUTION: Before you begin the following procedure, follow the safety instructions in the Product Information Guide .
    • NOTICE: To prevent static damage to components inside your computer, discharge static electricity from your body before you touch any of your computer's electronic components. You can do so by touching an unpainted metal surface. If you leave the area, ground yourself again when you return to the computer.
    • NOTE: Memory modules purchased from Dell are covered under your computer warranty.
    • NOTE: To get maximum performance/dual-channel memory bandwidth capability, both memory module connectors must contain memory modules and the modules must be of the same size and configuration.
    • NOTICE: To help prevent damage to the system board, you must remove the main battery before you begin working inside the computer
    • With the computer still turned over, loosen the captive screw on the memory module cover and slide the cover toward the back of the computer to remove it.
  2. XPS M2010 MXP061 Memory Module Replacement, Removing Securing Clamps: 手順 2、 1の画像 1
    • NOTICE: To prevent damage to the memory module connector, do not use tools to spread the memory-module securing clips.
    • Use your fingertips to carefully spread apart the securing clips on each end of the memory module connector until the module pops up.
  3. XPS M2010 MXP061 Memory Module Replacement, Removeing memory Module: 手順 3、 1の画像 1
    • Remove the module from the connector on the system board.
  4. XPS M2010 MXP061 Memory Module Replacement, Replacing the Memory Module: 手順 4、 1の画像 1
    • Align the notch on the edge of the memory module connector with the tab in the connector on the system board, and slide the module firmly into the connector at a 45-degree angle.
  5. XPS M2010 MXP061 Memory Module Replacement, Seating the Memory Module in place.: 手順 5、 1の画像 1
    • Rotate the module down until it clicks into place. If you do not feel the click, remove the module and reinstall it.
  6. XPS M2010 MXP061 Memory Module Replacement, Replace the memory cover: 手順 6、 1の画像 1
    • Replace the memory cover. Align the notches in the cover with the tabs on the base, slide the cover toward the front of the computer, and tighten the captive screw.
ゴール
2 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
Johnathan Hammond
メンバー登録日: 02/28/18
45,555 ポイント
408のガイドは作成済み
チーム
RampUP America, Inc. RampUP America, Inc.人のメンバー
Community
43 メンバー
1,994のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 8
今までの合計 301
