メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
X230T RAM Replacement
必要な工具と部品
  1. X230T RAM Replacement, Removing the battery: 手順 1、 1の画像 1
    • Start by removing the battery from the laptop. The battery should be removed to prevent damaging the motherboard when the RAM is installed and removed.
    • Slide the latch on the left to the left, and hold the other latch on the right to the right.
    • Slide out the battery, it should come out effortlessly.
    FixBotに聞いてみる
    コメントを追加
  2. X230T RAM Replacement, Removing the RAM cover: 手順 2、 1の画像 1
    • Undo the two screws that are circled, then, pry the RAM cover off by placing your finger nail or a spudger between the laptop and the RAM cover and puling up.
    FixBotに聞いてみる
    コメントを追加
  3. X230T RAM Replacement, Removing RAM: 手順 3、 3の画像 1 X230T RAM Replacement, Removing RAM: 手順 3、 3の画像 2 X230T RAM Replacement, Removing RAM: 手順 3、 3の画像 3
    • Remove the two clips from the RAM by pulling them slowly in the direction shown by the red arrows. When both clips are released, the RAM will lift up at a 45 degree angle (picture 2).
    • Once the RAM is at the angle as shown in picture 2, remove the RAM by pulling it out of the computer, as shown by the orange arrow.
    • If required, repeat the procedure for the other RAM module. The steps are the same.
    FixBotに聞いてみる
    コメントを追加
  4. X230T RAM Replacement, Installing RAM: 手順 4、 3の画像 1 X230T RAM Replacement, Installing RAM: 手順 4、 3の画像 2 X230T RAM Replacement, Installing RAM: 手順 4、 3の画像 3
    • To install the RAM, insert the new RAM with the notch on the RAM lining up to the notch on the slot. Slide the RAM in on a 45 degree angle as shown in picture 1.
    • Firmly push down the RAM until it is locked in place by the clips on either side. The clips will move around the RAM when the RAM is being inserted.
    • Put on the cover with the clips going in to the bottom edge of the cover first, then, tighten up the screws on the RAM cover.
    • Install the battery in to the computer, making sure the locking clips are engaged, and power the computer on.
    • Check the BIOS or your operating system to verify the RAM is working.
    FixBotに聞いてみる
    コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
2 の人々がこのガイドを完成させました。
作成者
1人の作成者と共同作成されました。
David Newberry
メンバー登録日: 04/20/17
394 ポイント
1ガイドが承認済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 5
過去 30 日: 34
今までの合計 1,391
