メインコンテンツにスキップ
はじめに
The steering column spring is responsible for reverting the wheels to a straight position when the remote is not turning one way or the other. A faulty steering column spring will fail to default to the straight position after turning the wheel.
パーツ
パーツは指定されていません。
  1. X-street Lamborghini Murcielago LP670-4 SV Steering Column Spring Replacement, Battery: 手順 1、 1の画像 1
    • Unscrew the two 2.5mm Phillips #00 screws from the middle of the car.
    • Unclip the two clips to remove the battery cover.
  2. X-street Lamborghini Murcielago LP670-4 SV Steering Column Spring Replacement: 手順 2、 1の画像 1
    • Unplug the battery by pushing on the clip.
  3. X-street Lamborghini Murcielago LP670-4 SV Steering Column Spring Replacement, Underbody: 手順 3、 1の画像 1
    • Unscrew the two 2.5mm Phillips #00 screws from each side
  4. X-street Lamborghini Murcielago LP670-4 SV Steering Column Spring Replacement: 手順 4、 1の画像 1
    • Remove the side skirt covers on each side of the car.
  5. X-street Lamborghini Murcielago LP670-4 SV Steering Column Spring Replacement: 手順 5、 2の画像 1 X-street Lamborghini Murcielago LP670-4 SV Steering Column Spring Replacement: 手順 5、 2の画像 2
    • Lift up and remove the two side skirts.
  6. X-street Lamborghini Murcielago LP670-4 SV Steering Column Spring Replacement: 手順 6、 1の画像 1
    • Unscrew the two 2.5mm Phillips #00 screws from the front skirt of the car.
  7. X-street Lamborghini Murcielago LP670-4 SV Steering Column Spring Replacement: 手順 7、 1の画像 1
    • Lift the front part of the underbody and pull it out from the main underbody.
  8. X-street Lamborghini Murcielago LP670-4 SV Steering Column Spring Replacement: 手順 8、 2の画像 1 X-street Lamborghini Murcielago LP670-4 SV Steering Column Spring Replacement: 手順 8、 2の画像 2
    • Unscrew the remaining seven 9mm Phillips #00 screws from the underbody of the car.
    • The second image shows a closer view of the rear three screws
  9. X-street Lamborghini Murcielago LP670-4 SV Steering Column Spring Replacement: 手順 9、 2の画像 1 X-street Lamborghini Murcielago LP670-4 SV Steering Column Spring Replacement: 手順 9、 2の画像 2
    • Lift the main underbody from the shell of the car.
    • Lift up the body to expose the wiring and hardware underneath.
  10. X-street Lamborghini Murcielago LP670-4 SV Steering Column Spring Replacement: 手順 10、 1の画像 1
    • Remove the reflective sticker from the top of the body.
  11. X-street Lamborghini Murcielago LP670-4 SV Steering Column Spring Replacement: 手順 11、 1の画像 1
    • Unplug the wire connector.
  12. X-street Lamborghini Murcielago LP670-4 SV Steering Column Spring Replacement, Steering Column: 手順 12、 3の画像 1 X-street Lamborghini Murcielago LP670-4 SV Steering Column Spring Replacement, Steering Column: 手順 12、 3の画像 2 X-street Lamborghini Murcielago LP670-4 SV Steering Column Spring Replacement, Steering Column: 手順 12、 3の画像 3
    • Unscrew the three 2.5mm Phillips #00 screws from the white steering column.
    • After removing the three screws, the steering column will pop out of position because of the springs underneath. To reassemble, put the springs back together as shown in picture #3.
  13. X-street Lamborghini Murcielago LP670-4 SV Steering Column Spring Replacement, Steering Column Spring: 手順 13、 1の画像 1
    • Remove the three 1.6mm Phillips #000 screws from the black motor casing.
  14. X-street Lamborghini Murcielago LP670-4 SV Steering Column Spring Replacement: 手順 14、 1の画像 1
    • Remove the front motor and its casing from the chassis of the car.
  15. X-street Lamborghini Murcielago LP670-4 SV Steering Column Spring Replacement: 手順 15、 1の画像 1
    • Carefully remove the steering column spring.
終わりに
ある他の人がこのガイドを完成しました。
Liam Martinez
メンバー登録日: 2015年04月01日
556 ポイント
5のガイドは作成済み
チーム
Cal Poly, Team 24-3, Lancaster Spring 2015 Cal Poly, Team 24-3, Lancaster Spring 2015人のメンバー
CPSU-LANCASTER-S15S24G3
3 メンバー
9のガイドは作成済み
0 件のコメント
コメントを追加
統計データを表示:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 2
今までの合計 207
