はじめに
The steering column spring is responsible for reverting the wheels to a straight position when the remote is not turning one way or the other. A faulty steering column spring will fail to default to the straight position after turning the wheel.
必要な工具と部品
Unscrew the two 2.5mm Phillips #00 screws from the middle of the car.
Unclip the two clips to remove the battery cover.
Remove the three 1.6mm Phillips #000 screws from the black motor casing.
ある他の人がこのガイドを完成しました。
