メインコンテンツにスキップ
X-street Lamborghini Murcielago LP670-4 SV Rear Motor Replacement
必要な工具と部品
  1. X-street Lamborghini Murcielago LP670-4 SV Rear Motor Replacement, Battery: 手順 1、 1の画像 1
    • Unscrew the two 2.5mm Phillips #00 screws from the middle of the car.
    • Unclip the two clips to remove the battery cover.
  2. X-street Lamborghini Murcielago LP670-4 SV Rear Motor Replacement: 手順 2、 1の画像 1
    • Unplug the battery by pushing on the clip.
  3. X-street Lamborghini Murcielago LP670-4 SV Rear Motor Replacement, Underbody: 手順 3、 1の画像 1
    • Unscrew the two 2.5mm Phillips #00 screws from each side
  4. X-street Lamborghini Murcielago LP670-4 SV Rear Motor Replacement: 手順 4、 1の画像 1
    • Remove the side skirt covers on each side of the car.
  5. X-street Lamborghini Murcielago LP670-4 SV Rear Motor Replacement: 手順 5、 2の画像 1 X-street Lamborghini Murcielago LP670-4 SV Rear Motor Replacement: 手順 5、 2の画像 2
    • Lift up and remove the two side skirts.
  6. X-street Lamborghini Murcielago LP670-4 SV Rear Motor Replacement: 手順 6、 1の画像 1
    • Unscrew the two 2.5mm Phillips #00 screws from the front skirt of the car.
  7. X-street Lamborghini Murcielago LP670-4 SV Rear Motor Replacement: 手順 7、 1の画像 1
    • Lift the front part of the underbody and pull it out from the main underbody.
  8. X-street Lamborghini Murcielago LP670-4 SV Rear Motor Replacement: 手順 8、 2の画像 1 X-street Lamborghini Murcielago LP670-4 SV Rear Motor Replacement: 手順 8、 2の画像 2
    • Unscrew the remaining seven 9mm Phillips #00 screws from the underbody of the car.
    • The second image shows a closer view of the rear three screws
  9. X-street Lamborghini Murcielago LP670-4 SV Rear Motor Replacement: 手順 9、 2の画像 1 X-street Lamborghini Murcielago LP670-4 SV Rear Motor Replacement: 手順 9、 2の画像 2
    • Lift the main underbody from the shell of the car.
    • Lift up the body to expose the wiring and hardware underneath.
  10. X-street Lamborghini Murcielago LP670-4 SV Rear Motor Replacement: 手順 10、 1の画像 1
    • Remove the reflective sticker from the top of the body.
  11. X-street Lamborghini Murcielago LP670-4 SV Rear Motor Replacement: 手順 11、 1の画像 1
    • Unplug the wire connector.
  12. X-street Lamborghini Murcielago LP670-4 SV Rear Motor Replacement, Rear Motor: 手順 12、 1の画像 1
    • Unscrew the two 2.5mm Phillips #00 screws on the white covering of the rear motor casing.
    • There is a plastic casing over the rear motor. Simply remove this plastic covering and proceed.
  13. X-street Lamborghini Murcielago LP670-4 SV Rear Motor Replacement: 手順 13、 2の画像 1 X-street Lamborghini Murcielago LP670-4 SV Rear Motor Replacement: 手順 13、 2の画像 2
    • Remove all ten 1.6mm Phillips #000 screws from the rear motor casing
    • The first image shows five screws on the side with the circuitry
    • The second image shows five screws on the opposite side of the casing.
  14. X-street Lamborghini Murcielago LP670-4 SV Rear Motor Replacement: 手順 14、 1の画像 1
    • Use a soldering gun to remove the attached wires
終わりに
ある他の人がこのガイドを完成しました。
作成者
4人の作成者と共同で作成されました。
Trent Peterson
メンバー登録日: 04/01/15
454 ポイント
3のガイドは作成済み
チーム
Cal Poly, Team 24-3, Lancaster Spring 2015 Cal Poly, Team 24-3, Lancaster Spring 2015人のメンバー
CPSU-LANCASTER-S15S24G3
3 メンバー
9のガイドは作成済み
コメント 1 件
what size is the motor
mattsson97 - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 1
今までの合計 496
