はじめに
The front steering motor provides power to the steering column which turns the wheels to one side. If the car fails to turn to one side or the other, it is possible the front steering motor needs replacement.
必要な工具と部品
Unscrew the two 2.5mm Phillips #00 screws from the middle of the car.
Unclip the two clips to remove the battery cover.
Remove the three 1.6mm Phillips #000 screws from the black motor casing
もう少しです!
終わりに
