はじめに
The Wyze Cam V2's speaker is responsible for producing sound and is an important part of the system. If your cam's audio is muffled or completely absent, the speaker may need to be replaced. This guide will help walk you through the steps of replacing a non-functioning speaker.
必要な工具と部品
Open up the camera stand to expose the bottom plate of the camera.
Remove two 4 mm silver screws using the Phillips #0 screwdriver.
この手順で使用する道具:Tweezers$3.99
Using the angled slim tweezers, disconnect the cord and pull it gently off of the motherboard.
Remove the two 6 mm screws from the back cover with a Phillips #0 screwdriver.
Carefully lift off the speaker plate.
