はじめに
One of the most important parts of a wrought iron door is the handle. Like other types of doors, the handle is in place to help with the opening, closing, and depending on the type of handle, additional security. Unfortunately, these handles can malfunction due to breakage or worn-out parts. This guide will include some basic steps on how to replace a handle to a wrought iron security door.
必要な工具と部品
ビデオの概要
First, open and then position the door to a desired width.
Secure the door by using the sliding latch of the cylinder or door prop.
Use a screwdriver to begin removing the screws from the handle.
Once the exterior handle is installed along with the lock shaft, align the new handle according to where the current holes are positioned.
Insert or thread the top and bottom screws by hand into the interior handle.
While holding the exterior handle in place, carefully insert the interior door handle along with the screws to connect with the exterior handle.
To reassemble the handle, follow these instructions in reverse order.
ある他の人がこのガイドを完成しました。
