メインコンテンツにスキップ
はじめに
The power switch turns the MiP on or off. If it's malfunctioning the robot will not work.
パーツ
パーツは指定されていません。
  1. WowWee MiP Robot Power Switch Replacement, Battery: 手順 1、 2の画像 1 WowWee MiP Robot Power Switch Replacement, Battery: 手順 1、 2の画像 2
    • Remove the three 12.0 mm Phillips # 2 screws from the battery cover.
  2. WowWee MiP Robot Power Switch Replacement: 手順 2、 2の画像 1 WowWee MiP Robot Power Switch Replacement: 手順 2、 2の画像 2
    • Carefully pull the battery pack from the robot.
    • Remove the batteries from the battery pack.
  3. WowWee MiP Robot Power Switch Replacement, Wheel: 手順 3、 2の画像 1 WowWee MiP Robot Power Switch Replacement, Wheel: 手順 3、 2の画像 2
    • Use a metal spudger to carefully pry off the hubcap without marring the plastic wheel or hubcap.
    • This plastic material is not replaceable. Any damage will be noticeable.
  4. WowWee MiP Robot Power Switch Replacement: 手順 4、 2の画像 1 WowWee MiP Robot Power Switch Replacement: 手順 4、 2の画像 2
    • Remove the 12.0 mm Phillips #2 screw.
    • Hold the wheel in place, or it will rotate as you attempt to remove the screw.
  5. WowWee MiP Robot Power Switch Replacement: 手順 5、 1の画像 1
    • Pull the wheel off of the square axle.
    • Do not use excessive force while removing the wheel. Pulling too hard on the wheel can damage the axle.
  6. WowWee MiP Robot Power Switch Replacement, WowWee MiP Robot Body Disassembly: 手順 6、 2の画像 1 WowWee MiP Robot Power Switch Replacement, WowWee MiP Robot Body Disassembly: 手順 6、 2の画像 2
    • Remove the eight 9.3 mm Phillips #1 screws from the back of the robot.
  7. WowWee MiP Robot Power Switch Replacement: 手順 7、 3の画像 1 WowWee MiP Robot Power Switch Replacement: 手順 7、 3の画像 2 WowWee MiP Robot Power Switch Replacement: 手順 7、 3の画像 3
    • Remove the arms from the body.
    • Carefully open the body compartment.
    • Open the compartment slowly. There are wires connecting the two body pieces together. If pulled too hard, the wires and/or the motherboard could be damaged.
  8. WowWee MiP Robot Power Switch Replacement: 手順 8、 1の画像 1
    • Using precision tweezers, disconnect the following three bundles of wires:
    • Connecting the battery pack to the motherboard.
    • Connecting the power switch to the motherboard.
    • Connecting the speaker to the motherboard.
  9. WowWee MiP Robot Power Switch Replacement, Power Switch: 手順 9、 2の画像 1 WowWee MiP Robot Power Switch Replacement, Power Switch: 手順 9、 2の画像 2
    • Remove the two 9.3mm Phillips #1 screws.
  10. WowWee MiP Robot Power Switch Replacement: 手順 10、 1の画像 1
    • Remove the power switch assembly from the body by gently pulling straight out on the wires.
終わりに
2 の人々がこのガイドを完成させました。
Daniel Burkholder
メンバー登録日: 2016年02月16日
623 ポイント
4のガイドは作成済み
チーム
USF Tampa, Team 3-4, Wollert Spring 2016 USF Tampa, Team 3-4, Wollert Spring 2016人のメンバー
USFT-WOLLERT-S16S3G4
4 メンバー
5のガイドは作成済み
コメント1件
where can i buy the power switch of MiP
Reinejoe Cacho - 返信
コメントを追加
統計データを表示:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 5
今までの合計 482
