メインコンテンツにスキップ
WowWee MiP Robot Battery Replacement
必要な工具と部品
  1. WowWee MiP Robot Battery Replacement, Battery: 手順 1、 2の画像 1 WowWee MiP Robot Battery Replacement, Battery: 手順 1、 2の画像 2
    • Remove the three 12.0 mm Phillips # 2 screws from the battery cover.
  2. WowWee MiP Robot Battery Replacement: 手順 2、 2の画像 1 WowWee MiP Robot Battery Replacement: 手順 2、 2の画像 2
    • Carefully pull the battery pack from the robot.
    • Remove the batteries from the battery pack.
終わりに
3 の人々がこのガイドを完成させました。
作成者
9人の作成者と共同で作成されました。
Moira Keahon
メンバー登録日: 09/24/14
257 ポイント
3のガイドは作成済み
チーム
University of Maine, Team 1-50, Diaz Fall 2014 University of Maine, Team 1-50, Diaz Fall 2014人のメンバー
UMAINE-DIAZ-F14S1G50
3 メンバー
6のガイドは作成済み
11 件のコメント
Its a programmer MIP not this kind.
Azariah Trumble - 返信
Same question here, instructions needed for CODER MIP as it doesn't seem to be a holding a charge.
Gil Acosta - 返信
does spare battery adapter vailable(not reachargeable)
coolboyz' channel - 返信
Coder Mip Battery says fully charged - but Coder Mip doesnt turn on?
Sadie - 返信
Coder MiP one day old - was working - battery says fully charged - but Coder MiP doesn’t turn on? Any suggestions?
Sadie - 返信
Brand new Coder MIP - fully charged (approx. 20 hours charging time) after 5-7 minutes in use, it run out of battery already. Is this normal?
Barbe _74 - 返信
Brand new Coder MiP (fully charged for approx. 20 hours) runs out of battery after only 5-7 minutes in use. Is this normal?
Barbe _74 - 返信
Same CODER MIP here - we got erratic performance from the battery pack. A smart slap seems required to ensure a tight battery connection after a robot fall, otherwise it appears to have run out of battery. Not optimal, but it allowed us to play for a while.
dagmarfraser - 返信
My Mip doesn’t work even if I replace the batteries. It acts very strange. It keeps making a clicking noise
Daniel Cleiland - 返信
I have A Coder MiP instead of a plain MiP
Are there different instructions.
Clarrie O'HARE - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 35
今までの合計 12,287
