Remove the 12.0 mm Phillips #2 screw.
Hold the wheel in place, or it will rotate as you attempt to remove the screw.
Remove the arms from the body.
Carefully open the body compartment.
Open the compartment slowly. There are wires connecting the two body pieces together. If pulled too hard, the wires and/or the motherboard could be damaged.
Using precision tweezers, disconnect the following three bundles of wires:
Connecting the battery pack to the motherboard.
Connecting the power switch to the motherboard.
Connecting the speaker to the motherboard.
Gently remove the speaker from the MiP.
During reassembly, be sure to place the speaker in the same position.
このガイドを埋め込む
サイズを選択し、以下のコードをコピーして、このガイドを小さなウィジェットとしてサイト/フォーラムに埋め込みます。
1つの手順
全ガイド
小サイズ - 600px
中サイズ - 800px
大サイズ - 1200px
プレビュー
