メインコンテンツにスキップ
はじめに
If simple sensor maintenance fails to solve the problem with your dryer, replacement may be necessary. This guide details steps taken for replacement of the sensor board for the World Dryer Airforce J4-973A3.
  1. In order to change the air filter, start with the removal of the outer metal casing. Using the special bit, remove the large screws at the bottom of the casing. To remove the case, lift the indicated spot with your hands.
    • In order to change the air filter, start with the removal of the outer metal casing.
    • Using the special bit, remove the large screws at the bottom of the casing.
    • To remove the case, lift the indicated spot with your hands.
    • The direction for turning the screws is different than what was indicated on the small sticker above the hole.
  2. Remove the 1/2" Ph1 screws at the bottom of the red fan cap. Turn over the unit. Push the red tabs on the back of the unit with medium to heavy pressure, using a plastic opening tool.
    • Remove the 1/2" Ph1 screws at the bottom of the red fan cap.
    • Turn over the unit.
    • Push the red tabs on the back of the unit with medium to heavy pressure, using a plastic opening tool.
    • Carefully remove the cap, to prevent damage to the sensor.
  3. Remove both 3/8" Ph2 screws attached to the grey belt at the top and bottom. Lift the grey belt away. This gives access to the server board.
    • Remove both 3/8" Ph2 screws attached to the grey belt at the top and bottom.
    • Lift the grey belt away. This gives access to the server board.
  4. Remove the rainbow ribbon cable from the middle circuit board, using a plastic opening tool. Remove the 1/2" Ph1 screw from the center of the circuit board. Remove the 1/2" Ph1 screw from the center of the circuit board.
    • Remove the rainbow ribbon cable from the middle circuit board, using a plastic opening tool.
    • Remove the 1/2" Ph1 screw from the center of the circuit board.
  5. Carefully remove the sensor board from your device.
    • Carefully remove the sensor board from your device.
まとめ
Luke Clancy
メンバー登録日: 2018年09月17日
123 ポイント
1ガイドが承認済み
チーム
Washington State, Team S1-G6, Hope Fall 2018 Washington State, Team S1-G6, Hope Fall 2018人のメンバー
WSU-HOPE-F18S1G6
4 メンバー
4のガイドは作成済み
コメントを追加する
統計データを表示:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 6
今までの合計 47
