メインコンテンツにスキップ
Wooting 60HE Keycap Replacement
必要な工具と部品
  1. Wooting 60HE Keycap Replacement, Keycap: 手順 1、 1の画像 1
    • Use a small, soft bristle brush to remove small hairs or dust from the keyboard.
    • For this replacement, we will be replacing the "A" keycap.
  2. Wooting 60HE Keycap Replacement: 手順 2、 2の画像 1 Wooting 60HE Keycap Replacement: 手順 2、 2の画像 2
    • Hook the two metal brackets of the keycap puller at a slight angle on the corners of the key.
    • Slightly tug upwards, and the key should come out smoothly. Place the key to the side.
    • It is essential to be gentle; excessive force can cause cracks or scratches on the key.
  3. Wooting 60HE Keycap Replacement: 手順 3、 1の画像 1
    この手順で使用する道具:
    • Using tweezers, carefully extract debris from the exposed backboard of the keyboard.
    • Try to avoid the key nub, as it is lubricated, and outside contact can ruin it.
  4. Wooting 60HE Keycap Replacement: 手順 4、 1の画像 1
    • Hold a multi-purpose electronics duster three inches away and at an angle from the exposed key.
    • Press the trigger in short bursts.
    • This will help get rid of any debris that you could not get from using your tweezers.
  5. Wooting 60HE Keycap Replacement: 手順 5、 2の画像 1 Wooting 60HE Keycap Replacement: 手順 5、 2の画像 2
    • Place a cotton swab on a napkin and lightly coat the head of the swab with 70% isopropyl alcohol.
  6. Wooting 60HE Keycap Replacement: 手順 6、 1の画像 1
    • Gently pat around the white backboard of the keyboard with the cotton swab.
    • This will help get rid of any built up residue, oils, or any possible spills that could have occurred in the past.
    • Isopropyl alcohol can strip the lubricant on the key, so put emphasis on dabbing the white backboard and not the key itself.
  7. Wooting 60HE Keycap Replacement: 手順 7、 3の画像 1 Wooting 60HE Keycap Replacement: 手順 7、 3の画像 2 Wooting 60HE Keycap Replacement: 手順 7、 3の画像 3
    • Line the keycap in the upright position above the nub and press down lightly.
    • The key should slide back in place.
ゴール
作成者
2人の作成者と共同で作成されました。
Aryav Balia
メンバー登録日: 10/25/23
157 ポイント
1ガイドが承認済み
チーム
CSU Los Angeles, Team 1-1, Briggs Fall 2023 CSU Los Angeles, Team 1-1, Briggs Fall 2023人のメンバー
CSULA-BRIGGS-F23S1G1
6 メンバー
5のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 3
過去 7 日: 19
過去 30 日: 59
今までの合計 781
