メインコンテンツにスキップ
Wolf Gourmet WGTR102S Electrical Connection Replacement
必要な工具と部品
  1. Wolf Gourmet WGTR102S Electrical Connection Replacement, Outer Shell: 手順 1、 1の画像 1
    • Using a wedge, pry off the rubber pieces on the bottom of each foot of the toaster.
  2. Wolf Gourmet WGTR102S Electrical Connection Replacement: 手順 2、 1の画像 1
    • Remove the eight 8mm screws on each toaster foot using a Tri-point Y1 screwdriver.
  3. Wolf Gourmet WGTR102S Electrical Connection Replacement: 手順 3、 1の画像 1
    • Remove the crumb collector located on the bottom of the toaster.
  4. Wolf Gourmet WGTR102S Electrical Connection Replacement: 手順 4、 1の画像 1
    • Remove the three 8mm screws using the Tri-point Y1 screwdriver.
  5. Wolf Gourmet WGTR102S Electrical Connection Replacement: 手順 5、 1の画像 1
    • Remove the two 8mm screws on the bottom of the slide lever using a Tri-point Y1 screwdriver.
    • Once the screws are removed, detach the black plastic cover on the bottom of the slide lever.
  6. Wolf Gourmet WGTR102S Electrical Connection Replacement: 手順 6、 1の画像 1
    • Remove the final 8mm screw in the slide lever.
    • The lever can now pull away from the entire unit.
  7. Wolf Gourmet WGTR102S Electrical Connection Replacement: 手順 7、 1の画像 1
    • Remove toaster's outer shell by lifting straight up.
    • Slowly remove the outer shell. Disconnect ground wire before fully separating the shell and inner components.
  8. Wolf Gourmet WGTR102S Electrical Connection Replacement: 手順 8、 2の画像 1 Wolf Gourmet WGTR102S Electrical Connection Replacement: 手順 8、 2の画像 2
    • Disconnect the wire cluster that connects the lights and circuit board by pulling apart the two plastic connectors.
    • Remove the outer shell from the device.
  9. Wolf Gourmet WGTR102S Electrical Connection Replacement, Electrical Connection: 手順 9、 1の画像 1
    • Unscrew the ground wire using a Tri-point Y1 screwdriver. It is secured with an 8mm screw.
  10. Wolf Gourmet WGTR102S Electrical Connection Replacement: 手順 10、 1の画像 1
    • Use pliers to pull apart the three electrical connectors pictured in the graphic.
  11. Wolf Gourmet WGTR102S Electrical Connection Replacement: 手順 11、 1の画像 1
    • Replace the electrical connectors.
終わりに
ある他の人がこのガイドを完成しました。
作成者
2人の作成者と共同で作成されました。
Ryan Funchess
メンバー登録日: 04/19/18
715 ポイント
5のガイドは作成済み
チーム
Cal Poly, Team S22-G5, Maness Spring 2018 Cal Poly, Team S22-G5, Maness Spring 2018人のメンバー
CPSU-MANESS-S18S22G5
4 メンバー
5のガイドは作成済み
コメント 1 件
Ryan Funchess
Thank you for you work on this toaster. My customer is happy.
Adam Hunsinger - 返信
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 11
今までの合計 857
