メインコンテンツにスキップ
Wolf Gourmet WGBL100S Power Cord Replacement
必要な工具と部品
  1. Wolf Gourmet WGBL100S Power Cord Replacement, Power Cord: 手順 1、 2の画像 1 Wolf Gourmet WGBL100S Power Cord Replacement, Power Cord: 手順 1、 2の画像 2
    • With the bottom of the blender facing up, use a Phillips #2 screwdriver to remove the 4, 1/2 inch long screws in the corners of the device.
    • Ensure the blender is off and unplugged before starting.
  2. Wolf Gourmet WGBL100S Power Cord Replacement: 手順 2、 2の画像 1 Wolf Gourmet WGBL100S Power Cord Replacement: 手順 2、 2の画像 2
    • Using a metal spudger, pry up one side of each of the rubber feet.
    • Note that one side of each foot is glued down; pry up the non-glued side.
  3. Wolf Gourmet WGBL100S Power Cord Replacement: 手順 3、 1の画像 1
    • Using the same Phillips #2 screwdriver, unscrew the 1/2 inch long screw under each of the feet.
  4. Wolf Gourmet WGBL100S Power Cord Replacement: 手順 4、 2の画像 1 Wolf Gourmet WGBL100S Power Cord Replacement: 手順 4、 2の画像 2
    • Pull off the base and remove the plastic housing underneath.
  5. Wolf Gourmet WGBL100S Power Cord Replacement: 手順 5、 2の画像 1 Wolf Gourmet WGBL100S Power Cord Replacement: 手順 5、 2の画像 2
    • On the underside of the base, unscrew the three 3/8" long screws on the plastic piece holding the power cord in place using a Phillips #1 screwdriver.
    • Pull the plastic cover off.
  6. Wolf Gourmet WGBL100S Power Cord Replacement: 手順 6、 1の画像 1
    • Using a wire cutter, cut the three wires of the power cord.
  7. Wolf Gourmet WGBL100S Power Cord Replacement: 手順 7、 2の画像 1 Wolf Gourmet WGBL100S Power Cord Replacement: 手順 7、 2の画像 2
    • Pull the cut power cord through the base.
    • Then thread the replacement cord back through and re-attach the plastic cover.
  8. Wolf Gourmet WGBL100S Power Cord Replacement: 手順 8、 3の画像 1 Wolf Gourmet WGBL100S Power Cord Replacement: 手順 8、 3の画像 2 Wolf Gourmet WGBL100S Power Cord Replacement: 手順 8、 3の画像 3
    • Strip about an inch of insulation off of the snipped power cord and your replacement cord.
    • Twist each strand of wires together to keep them neat.
  9. Wolf Gourmet WGBL100S Power Cord Replacement: 手順 9、 2の画像 1 Wolf Gourmet WGBL100S Power Cord Replacement: 手順 9、 2の画像 2
    • Twist together the wires from the replacement cord to the wires still attached to the blender.
    • Solder the connection if possible.
  10. Wolf Gourmet WGBL100S Power Cord Replacement: 手順 10、 2の画像 1 Wolf Gourmet WGBL100S Power Cord Replacement: 手順 10、 2の画像 2
    • Wrap all the connections in electrical tape or heat shrink tubing.
終わりに
To reassemble your device, follow steps 1-5 in reverse order.
ある他の人がこのガイドを完成しました。
作成者
3人の作成者と共同で作成されました。
Cole Gillespie
メンバー登録日: 04/19/18
476 ポイント
2のガイドは作成済み
チーム
Cal Poly, Team S25-G16, Maness Spring 2018 Cal Poly, Team S25-G16, Maness Spring 2018人のメンバー
CPSU-MANESS-S18S25G16
4 メンバー
5のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 8
今までの合計 267
