メインコンテンツにスキップ
Wireless Xbox One Controller Bumper Assembly Replacement
必要な工具と部品
  1. Wireless Xbox One Controller Bumper Assembly Replacement, Bumper Assembly: 手順 1、 1の画像 1
    • Remove the battery cover from the back of the controller by sliding it upwards.
  2. Wireless Xbox One Controller Bumper Assembly Replacement: 手順 2、 3の画像 1 Wireless Xbox One Controller Bumper Assembly Replacement: 手順 2、 3の画像 2 Wireless Xbox One Controller Bumper Assembly Replacement: 手順 2、 3の画像 3
    この手順で使用する道具:
    Halberd Spudger
    $2.99
    • Using the halberd spudger, pry the grip casing upwards from the handle.
    • Remove the grip casing from both the left and right handles of the controller.
    • It helps to begin near the top of the grip casing near the trigger.
  3. Wireless Xbox One Controller Bumper Assembly Replacement: 手順 3、 2の画像 1 Wireless Xbox One Controller Bumper Assembly Replacement: 手順 3、 2の画像 2
    • Remove the five 9 mm Torx TR9 security screws from the top and bottom of the controller grip regions as well as from the center of the battery region.
    • The pins on the security screws can be broken off easily with a small flathead screwdriver for use of an ordinary Torx screwdriver if the security version is unavailable.
  4. Wireless Xbox One Controller Bumper Assembly Replacement: 手順 4、 1の画像 1
    • Remove the back of the controller casing by lifting it up and off.
  5. Wireless Xbox One Controller Bumper Assembly Replacement: 手順 5、 1の画像 1
    • Lift the internal assembly from the plastic controller case.
    • Handle gently; the motors on the bottom left and right are not firmly attached.
  6. Wireless Xbox One Controller Bumper Assembly Replacement: 手順 6、 2の画像 1 Wireless Xbox One Controller Bumper Assembly Replacement: 手順 6、 2の画像 2
    • Remove the top button panel from the controller by gently lifting up the hooks attached to the internals.
  7. Wireless Xbox One Controller Bumper Assembly Replacement: 手順 7、 1の画像 1
    • Detach the bumper assembly by sliding one bumper to the side away from the controller and then lifting upwards.
    • Gently follow the motion indicated by the arrows.
  8. Wireless Xbox One Controller Bumper Assembly Replacement: 手順 8、 1の画像 1
    • Remove bumpers and replace by inserting a new bumper assembly.
終わりに
14 の人々がこのガイドを完成させました。
作成者
4人の作成者と共同で作成されました。
Patrick Ashman
メンバー登録日: 01/30/23
384 ポイント
1ガイドが承認済み
チーム
Cal Poly, Team 2-2, Johann Winter 2023 Cal Poly, Team 2-2, Johann Winter 2023人のメンバー
CPSU-JOHANN-W23S2G2
3 メンバー
3のガイドは作成済み
1件のガイドコメント
hie my controller vibrate and goes off immediately I start using it kindly assist
Shakes makena - 返信
コメントを追加
統計データ:
過去 24時間: 11
過去 7 日: 115
過去 30 日: 493
今までの合計 14,119
