メインコンテンツにスキップ
Wintec Filemate Clear 7" Motherboard Replacement
必要な工具と部品
  1. Wintec Filemate Clear 7" Motherboard Replacement, Remove the Backplate: 手順 1、 1の画像 1
    • Locate the four corners of the backplate.
  2. Wintec Filemate Clear 7" Motherboard Replacement: 手順 2、 2の画像 1 Wintec Filemate Clear 7" Motherboard Replacement: 手順 2、 2の画像 2
    • Pry off the backplate by inserting a spudger or plastic opening tool into each corner and popping them open.
  3. Wintec Filemate Clear 7" Motherboard Replacement, Remove the Battery: 手順 3、 1の画像 1
    • Un-stick the battery from the motherboard assembly with the plastic opening tool.
  4. Wintec Filemate Clear 7" Motherboard Replacement: 手順 4、 1の画像 1
    この手順で使用する道具:
    • Desolder the battery wires from the motherboard.
    • The tweezers pictured point to the two solder joints.
  5. Wintec Filemate Clear 7" Motherboard Replacement: 手順 5、 1の画像 1
    • Fully remove the battery from the device.
  6. Wintec Filemate Clear 7" Motherboard Replacement, Motherboard: 手順 6、 1の画像 1
    • Locate each of the motherboard's 4 mm screws.
  7. Wintec Filemate Clear 7" Motherboard Replacement, Unscrewing Everything: 手順 7、 3の画像 1 Wintec Filemate Clear 7" Motherboard Replacement, Unscrewing Everything: 手順 7、 3の画像 2 Wintec Filemate Clear 7" Motherboard Replacement, Unscrewing Everything: 手順 7、 3の画像 3
    • Remove each of the four 4 mm screws from the motherboard pictured to the left.
    • Use a Phillips #00 precision screwdriver.
  8. Wintec Filemate Clear 7" Motherboard Replacement, Detach the Motherboard: 手順 8、 2の画像 1 Wintec Filemate Clear 7" Motherboard Replacement, Detach the Motherboard: 手順 8、 2の画像 2
    • Use the spudger to pry the instrument array from its plastic housing.
  9. Wintec Filemate Clear 7" Motherboard Replacement: 手順 9、 1の画像 1
    • Slowly slide the spudger underneath the adhesive tape to un-sitck it.
    • Be careful not to harm the array of wires leading to this tape.
  10. Wintec Filemate Clear 7" Motherboard Replacement: 手順 10、 1の画像 1
    この手順で使用する道具:
    • De-tatch the motherboard output wires from the screen using the tweezers.
終わりに
作成者
5人の作成者と共同で作成されました。
Nicholas Ferraro
メンバー登録日: 01/20/15
431 ポイント
6のガイドは作成済み
チーム
USF Tampa, Team 19-6, Blackwell Spring 2014 USF Tampa, Team 19-6, Blackwell Spring 2014人のメンバー
USFT-BLACKWELL-S14S19G6
3 メンバー
11のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 2
今までの合計 174
