はじめに
To complete this guide, you will need to take apart the tablet almost completely.
必要な工具と部品
Un-stick the battery from the motherboard assembly with the plastic opening tool.
Remove each of the four 4 mm screws from the motherboard pictured to the left.
Use a Phillips #00 precision screwdriver.
There are two additional 4 mm screws holding the front screen.
Use the Phillips #00 screwdriver to remove the screws (pictured to the left).
終わりに
1件のガイドコメント
Hi, have a Filemate tablet and the front is broke . So is the Front and Digitizer the same thing? Thank you Brenda L Glidewell
