はじめに
To complete this guide, you will need precision accuracy and some elbow grease.
Un-stick the battery from the motherboard assembly with the plastic opening tool.
手順6 Motherboard
注意: 手順 6-10 は、作業進行中としてマークされている ガイド から引用されています。
Locate each of the motherboard's 4 mm screws.
Remove each of the four 4 mm screws from the motherboard pictured to the left.
Use a Phillips #00 precision screwdriver.
Remove the charging pin holster.
Clamp on the end of the holster with the tweezers and twist until it becomes detached.
Repeat for the other side.
To reassemble your device, follow these instructions in reverse order. The charging pin holster needs to be soldered back into place.
ある他の人がこのガイドを完成しました。
