はじめに
This guide will help you to replace your motherboard. For this replacement, You will need the tool #PH0 and tweezers.
必要な工具と部品
Place Gamepad face down and remove the two 4.7 mm screws with a Phillips size #00 screwdriver.
Remove 10 9mm screws with Tri-Wing size Y1 screwdriver around the outer case.
Lift up on the back of case.
13 の人々がこのガイドを完成させました。
2 件のコメント
How can i see what version off motherboard i need to buy to replace it
I got 30X52504 as number on the board
