はじめに
This guide will help you to replace your camera. For this replacement, you will need to use tweezers.
必要な工具と部品
Place Gamepad face down and remove the two 4.7 mm screws with a Phillips size #00 screwdriver.
Remove 10 9mm screws with Tri-Wing size Y1 screwdriver around the outer case.
Lift up on the back of case.
Flip motherboard over.
Remove the metal housing around the camera with tweezers.
もう少しです!
終わりに
