はじめに
このガイドではオーディオに問題があるスピーカーを交換します。
必要な工具と部品
指先で、バッテリーコネクターのプラグを押して後ろ向きに引きます。
バッテリーケースからバッテリーを取り出します。
外側ケース周辺に留められたトライウイング用のY1ドライバーで9mmネジを10本外します。
ケースの裏側を持ち上げます。
指でマザーボードから外側ケースのモーターコネクターの接続を外します。
I agree. A circle over the plug would have been better as the picture looks like you just pull on the wires lol.
Chris -
Thanks for the comment. I did get a set of tweezers and the negative cable broke anyway. They really could have done a better job at using a different connector for that.
Why in the world is this thing so tightly connected?
Thanks for the comment. I did get a set of tweezers to try to pull it out but still ended up breaking the negative cable. They really could have used a better set of cables and connectors for this.
マザーボードから左側スピーカーケーブルの接続を指で外します。
Speakers are connected with solder so removing them is not possible without requiring soldering later on. I left them both connected and instead of removing the motherboard completely I just "hinged" it carefully down to facilitate the work following step 18.
Thank you for offering this info because I spent 20 minutes between scratching my head and searching for any alternatives to just the image above, which had a wire nut/housing (and mine certainly did not). As I began to have an anxiety attack (
Mine also did not have connectors for the speaker. But like mentioned above, I was able to do repair WITHOUT the need to unsolder the speaker wires. Thanks!
ピンセットを使って、マザーボードと接続されている右側スピーカーケーブルを取り出します。
Note that on some units (presumably later ones), the speakers are soldered onto the motherboard.
デバイスを再組み立てする際は、これらのインストラクションを逆の順番に従って作業を進めてください。
6 の人々がこのガイドを完成させました。
以下の翻訳者の皆さんにお礼を申し上げます:
100%
翻訳を始める ›
tried to unscrew the 10 Tri-Wing size Y1 screw with my iFixIt toolkit
unfortunately the tool is too “fat” and short, it cannot reach 4 screws on the corners of the gamepad.
having the iFixIt toolkit and needing to purchase an additional slim screwdriver it’s a shame…
Antonello Iannone - 返信
