メインコンテンツにスキップ
はじめに
This guide will demonstrate how to replace the Power Supply inside the Wii Balance Board.
  1. Wii Balance Board Frame Replacement, Unscrewing the Foot Cover: 手順 1、 1の画像 1
    • Flip device upside-down so the plastic white board is facing the ground.
    • Locate the four feet in the corners of the Balance Board.
    • Unscrew the three 12.7 mm Phillips screws from each foot cover.
  2. Wii Balance Board Frame Replacement, Removing the Foot Cover: 手順 2、 1の画像 1
    • Remove the gray plastic ring from the actual foot by lifting it up.
  3. Wii Balance Board Frame Replacement, Removing the Foot: 手順 3、 1の画像 1
    • Separate the loose foot from the device by lifting it up.
  4. Wii Balance Board Frame Replacement, Removing the Additional Feet: 手順 4、 1の画像 1
    • Repeat steps two and three on the remaining four feet.
  5. Wii Balance Board Frame Replacement, Unscrewing the Back Cover: 手順 5、 1の画像 1
    • Unscrew the ten 12.7 mm Phillips #1 screws.
  6. Wii Balance Board Frame Replacement, Removing the Back Cover: 手順 6、 1の画像 1
    • Lift off the gray back cover.
  7. Wii Balance Board Frame Replacement, Battery Compartment: 手順 7、 2の画像 1 Wii Balance Board Frame Replacement, Battery Compartment: 手順 7、 2の画像 2
    • Locate the gray battery compartment.
    • Push the tab on the bottom and lift up completely to remove the cover to the batteries.
  8. Wii Balance Board Frame Replacement, Removing the Battery Case: 手順 8、 1の画像 1
    • Unscrew the two 6.35 mm Phillips #1 screws.
    • Slide the battery case out.
  9. Wii Balance Board Frame Replacement, Unscrewing the Frame: 手順 9、 1の画像 1
    • Unscrew the four 12.7 mm #1 screws.
  10. Wii Balance Board Frame Replacement, Removing the Frame: 手順 10、 1の画像 1
    • Lift the frame, circuit board, and power supply out of the front case. These components are all connected.
  11. Wii Balance Board Frame Replacement, Removing the Power Supply: 手順 11、 1の画像 1
    • Lift out the power supply. It is not screwed in.
終わりに
Cory Olson
メンバー登録日: 2014年09月29日
840 ポイント
4のガイドは作成済み
チーム
Cal Poly, Team 13-8, Forte Fall 2014 Cal Poly, Team 13-8, Forte Fall 2014人のメンバー
CPSU-FORTE-F14S13G8
5 メンバー
15のガイドは作成済み
0 件のコメント
コメントを追加
統計データを表示:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 17
今までの合計 2,176
