メインコンテンツにスキップ
Wii Balance Board Battery Case Replacement
必要な工具と部品
  1. Wii Balance Board Battery Case Replacement, Unscrewing the Foot Cover: 手順 1、 1の画像 1
    • Flip device upside-down so the plastic white board is facing the ground.
    • Locate the four feet in the corners of the Balance Board.
    • Unscrew the three 12.7 mm Phillips screws from each foot cover.
  2. Wii Balance Board Battery Case Replacement, Removing the Foot Cover: 手順 2、 1の画像 1
    • Remove the gray plastic ring from the actual foot by lifting it up.
  3. Wii Balance Board Battery Case Replacement, Removing the Foot: 手順 3、 1の画像 1
    • Separate the loose foot from the device by lifting it up.
  4. Wii Balance Board Battery Case Replacement, Removing the Additional Feet: 手順 4、 1の画像 1
    • Repeat steps two and three on the remaining four feet.
    how to completely remove and then put back in would be helpful as that's what the title of this post is…. right?
    Nelda Murray - 返信
  5. Wii Balance Board Battery Case Replacement, Unscrewing the Back Cover: 手順 5、 1の画像 1
    • Unscrew the ten 12.7 mm Phillips #1 screws.
  6. Wii Balance Board Battery Case Replacement, Removing the Back Cover: 手順 6、 1の画像 1
    • Lift off the gray back cover.
    Top Anleitung, aber kann nirgends die Platine finden.... Könnt ihr da helfen? Danke!!!
    Dominik - 返信
  7. Wii Balance Board Battery Case Replacement, Battery Compartment: 手順 7、 2の画像 1 Wii Balance Board Battery Case Replacement, Battery Compartment: 手順 7、 2の画像 2
    • Locate the gray battery compartment.
    • Push the tab on the bottom and lift up completely to remove the cover to the batteries.
  8. Wii Balance Board Battery Case Replacement, Removing the Battery Case: 手順 8、 1の画像 1
    • Unscrew the two 6.35 mm Phillips #1 screws.
    • Slide the battery case out.
    Just wanted to say THANKS it really helped & saved me having to get a new one or repaired. u rock! Sending good karma your way!
    scottydecept - 返信
    Were can I get a battery case replacement holder for my wii fit balance board
    Jacqueline Booth - 返信
    Do we wipe down something after that?
    Kandace Lavender - 返信
    New batteries. Start “button" blinks, then turns off. Any suggestions?
    Ginny Butler - 返信
    After removing it I soaked the battery case in vinegar for maybe 30 minutes. A little toothbrush work and all of the crap was gone. Rinsed it, dried it, put it back in. While it soaked I also used vinegar on the spring battery terminal that is cabled to the base. Cleaned up very nicely.
    jatrac1 - 返信
終わりに
16 の人々がこのガイドを完成させました。
作成者
6人の作成者と共同で作成されました。
Michelle Reed
メンバー登録日: 09/29/14
447 ポイント
1ガイドが承認済み
チーム
Cal Poly, Team 13-8, Forte Fall 2014 Cal Poly, Team 13-8, Forte Fall 2014人のメンバー
CPSU-FORTE-F14S13G8
5 メンバー
15のガイドは作成済み
14 件のコメント
I unscrewed everything, but were do i find a replacement battery compartent?
Olivia C - 返信
Then what do you do after you remove the battery case?
CRAIG WIKMAN - 返信
Is there a way to open the top of the board by sliding or lifting the top? I bought a gently used wii fit. The lady who sold it to me very quickly opened the top of the board from the centre seam to show me the instruction manual and I think hook up cables. I cannot, for the life of me figure out how she did it! Any ideas or technical wizardry you can share?
Frustrated in Canada!
Pam Murray - 返信
u rock - it totally worked
scottydecept - 返信
Why tell to remove all those parts and then there's no replacement battery board
Valerie Triplin - 返信
Thanks for this. i bought the replacement battery compartment a while ago but didn’t dare try to do it. Your instructions were clear to follow, so I did it in 20 mins. Thanks again.
Fire Storm - 返信
Hi there where did you get the replacement battery compartment from please? Thanks
helenhodson -
Can you please let us know where to purchase the replacement battery compartment?
daviddames -
Where can I find a replacement battery board?
Frederick Bergeron - 返信
Any link to a replacement compartment?
Kizzy Worth - 返信
Can be helpful if you need to clean the battery holder after the battery has leaked, rather remove the battery box than put liquid near the pcb's. - thanks!
Alan Harrison - 返信
What you do next is… check Amazon for a GameOn Fit Balance Rechargeable Battery Pack (Wii) , then look at Ebay to find one at half the price!
Lawrence Armour - 返信
I want remoot from wherei can get one ?
محمد ابورزق - 返信
wo kann ich ein neues Batteriefach dafür, kaufen??. antwort bitte auf :batascheen@gmail.com:
Renate Herbst - 返信
コメントを追加
統計データ:
過去 24時間: 5
過去 7 日: 42
過去 30 日: 270
今までの合計 41,582
