メインコンテンツにスキップ
Wii Balance Board Battery Case Replacement
必要な工具と部品
  1. Wii Balance Board Battery Case Replacement, Unscrewing the Foot Cover: 手順 1、 1の画像 1
    • Flip device upside-down so the plastic white board is facing the ground.
    • Locate the four feet in the corners of the Balance Board.
    • Unscrew the three 12.7 mm Phillips screws from each foot cover.
  2. Wii Balance Board Battery Case Replacement, Removing the Foot Cover: 手順 2、 1の画像 1
    • Remove the gray plastic ring from the actual foot by lifting it up.
  3. Wii Balance Board Battery Case Replacement, Removing the Foot: 手順 3、 1の画像 1
    • Separate the loose foot from the device by lifting it up.
  4. Wii Balance Board Battery Case Replacement, Removing the Additional Feet: 手順 4、 1の画像 1
    • Repeat steps two and three on the remaining four feet.
  5. Wii Balance Board Battery Case Replacement, Unscrewing the Back Cover: 手順 5、 1の画像 1
    • Unscrew the ten 12.7 mm Phillips #1 screws.
  6. Wii Balance Board Battery Case Replacement, Removing the Back Cover: 手順 6、 1の画像 1
    • Lift off the gray back cover.
  7. Wii Balance Board Battery Case Replacement, Battery Compartment: 手順 7、 2の画像 1 Wii Balance Board Battery Case Replacement, Battery Compartment: 手順 7、 2の画像 2
    • Locate the gray battery compartment.
    • Push the tab on the bottom and lift up completely to remove the cover to the batteries.
  8. Wii Balance Board Battery Case Replacement, Removing the Battery Case: 手順 8、 1の画像 1
    • Unscrew the two 6.35 mm Phillips #1 screws.
    • Slide the battery case out.
終わりに
16 の人々がこのガイドを完成させました。
作成者
6人の作成者と共同で作成されました。
Michelle Reed
メンバー登録日: 09/29/14
447 ポイント
1ガイドが承認済み
チーム
Cal Poly, Team 13-8, Forte Fall 2014 Cal Poly, Team 13-8, Forte Fall 2014人のメンバー
CPSU-FORTE-F14S13G8
5 メンバー
15のガイドは作成済み
14 件のコメント
I unscrewed everything, but were do i find a replacement battery compartent?
Olivia C - 返信
Then what do you do after you remove the battery case?
CRAIG WIKMAN - 返信
Is there a way to open the top of the board by sliding or lifting the top? I bought a gently used wii fit. The lady who sold it to me very quickly opened the top of the board from the centre seam to show me the instruction manual and I think hook up cables. I cannot, for the life of me figure out how she did it! Any ideas or technical wizardry you can share?
Frustrated in Canada!
Pam Murray - 返信
u rock - it totally worked
scottydecept - 返信
Why tell to remove all those parts and then there's no replacement battery board
Valerie Triplin - 返信
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 68
過去 30 日: 250
今までの合計 42,345
