メインコンテンツにスキップ
この翻訳は、ソースガイドの最新の更新を反映していない可能性があります。 翻訳の更新に協力してください。 または ソースガイドを参照してください
Why! NH57ADS Fan and Heatsink Removal
必要な工具と部品
  1. Why! NH57ADS Fan and Heatsink Removal, Battery: 手順 1、 3の画像 1 Why! NH57ADS Fan and Heatsink Removal, Battery: 手順 1、 3の画像 2 Why! NH57ADS Fan and Heatsink Removal, Battery: 手順 1、 3の画像 3
    • Remove the two screws holding the battery in place.
    • Slip your finger into the finger hole provided at the top of the battery and lift to remove it.
  2. Why! NH57ADS Fan and Heatsink Removal, Bottom Cover: 手順 2、 3の画像 1 Why! NH57ADS Fan and Heatsink Removal, Bottom Cover: 手順 2、 3の画像 2 Why! NH57ADS Fan and Heatsink Removal, Bottom Cover: 手順 2、 3の画像 3
    • Remove the five Phillips screws securing the bottom to the case.
    • Slide the cover up slightly to release the catches holding it in place. This is the view on the right. The mark on the cover should now line up with the second mark on the case of the computer.
  3. Why! NH57ADS Fan and Heatsink Removal, Removing the Bottom Cover: 手順 3、 3の画像 1 Why! NH57ADS Fan and Heatsink Removal, Removing the Bottom Cover: 手順 3、 3の画像 2 Why! NH57ADS Fan and Heatsink Removal, Removing the Bottom Cover: 手順 3、 3の画像 3
    • This is the view on the left before and after sliding the cover. The mark on the cover should now line up with the second mark on the case of the computer.
    • Lift the bottom cover to remove it.
  4. Why! NH57ADS Fan and Heatsink Removal, Fan: 手順 4、 3の画像 1 Why! NH57ADS Fan and Heatsink Removal, Fan: 手順 4、 3の画像 2 Why! NH57ADS Fan and Heatsink Removal, Fan: 手順 4、 3の画像 3
    • Remove the three Phillips screws securing the fan on the right.
    • Carefully unplug the fan's power connector.
    • Remove the first fan.
  5. Why! NH57ADS Fan and Heatsink Removal, Fan and Heatsink Assembly: 手順 5、 3の画像 1 Why! NH57ADS Fan and Heatsink Removal, Fan and Heatsink Assembly: 手順 5、 3の画像 2 Why! NH57ADS Fan and Heatsink Removal, Fan and Heatsink Assembly: 手順 5、 3の画像 3
    • Remove the two Phillips screws securing the left hand fan.
    • Remove the six Phillips heatsink retaining screws .
    • Using the two black tabs as handles, lift and remove the heatsink.
終わりに
To reassemble your device, follow the instructions in reverse order.
以下の翻訳者の皆さんにお礼を申し上げます:
fr en
50%
Jerry Wheelerさんは世界中で修理する私たちを助けてくれています! あなたも貢献してみませんか?
翻訳を始める ›
作成者
2人の作成者と共同で作成されました。
Felice Suglia
メンバー登録日: 06/15/13
31,100 ポイント
264のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 4
過去 30 日: 10
今までの合計 99
