はじめに
A stuck washplate (also called a wash plate, pulsator, or agitator plate) can keep you from accessing the hub and can cause poor washing performance if it can’t move freely. This guide walks through several progressively stronger, low-damage techniques to loosen and remove a stubborn Whirlpool-built washplate using cleaning chemistry, test cycles, and safer prying tools.
必要な工具と部品
手順1 Prepare for safe work
Unplug the washer before disassembly, and keep the plug out of reach.
Turn off the water supply valves if you plan to swap hoses or work with the lid open for extended periods.
手順2 Remove the washplate center cap
Use a flathead screwdriver to pry up and remove the center cap from the washplate.
手順3 Remove the washplate bolt
Use a ratchet with a 16 mm or 7/16 inch socket to remove the transmission screw or bolt in the center of the washplate.
Use an impact gun to loosen the bolt if it’s seized and a hand ratchet won’t break it free.
手順4 Add citric acid to break down buildup
Pour about 1 to 1.5 cups of citric acid powder into the tub.
Fill the tub with hot water to help loosen debris and buildup under the washplate.
手順5 Choose a cycle method to loosen the plate
Run a regular wash cycle with the hottest water setting available to help the citric acid work under the washplate.
Fill the tub with hot water and use the washer’s test mode if you want agitation or spin without quickly pumping out the citric-acid water.
Run a cold cycle with the hot and cold supply lines swapped if the washer won’t request hot water in the mode you need.
手順6 Bypass the lid lock for monitoring
Use a Torx screwdriver to remove the lid lock striker from the lid.
Insert the striker into the lid lock to trick the washer into thinking the lid is closed.
手順7 Run agitation or spin in test mode
Enter the washer’s service test system and select a manual test mode.
Engage the lid lock in the test mode, since agitation and spin won’t run without it.
Select a gentle mode and press the Start button to begin agitation.
Repeat the agitation test as needed, since this test typically only runs agitation for about a minute.
Press Start to stop the test and switch to spin mode, or another desired mode, when you want to change the motion.
手順8 Drain the dirty water before prying
Use a drain mode to pump out the dirty citric-acid water before attempting removal.
Wipe off splashed debris from the lid and rim so it doesn’t fall back into the tub while you work.
手順9 Pull up using a trampoline spring tool
Use a trampoline spring tool to hook into the washplate’s plastic holes or edges and pull upward.
File down the tool’s tip slightly so it fits and bites into the plastic better than a standard screwdriver.
Work around the washplate, pulling from different points instead of trying to yank from a single spot.
手順10 Troubleshoot a stubborn washplate without cracking it
Try sliding a putty knife under the washplate if you need a thinner tool, but expect limited grip on some plates.
Refill the tub with water and add more citric acid at a lower concentration if the plate is still stuck.
Repeat agitation and spin test runs to gradually loosen the plate instead of forcing it off in one attempt.
手順11 Use rocking motion if it starts to release
Add more citric acid and an orange degreaser to the tub if buildup is still binding the plate.
Roll the liquid around the tub and push the washplate back and forth until it breaks free.
手順12 Remove the washplate and assess results
Lift the washplate out of the tub once it releases.
Inspect and clean the area under the washplate, since the citric acid should have loosened and floated debris.
Reinstall the washplate bolt and center cap after cleaning, and run a rinse or wash cycle to flush out any remaining loosened debris. If the washplate is still stuck, repeat the citric-acid soak and short agitation tests, focusing on time and even lifting pressure rather than force on one side.
