はじめに
If your Whirlpool refrigerator’s (Type 21MCD, Model WRS571CIHV00) lightbulb has gone out or stopped working, you most likely need to replace the lightbulb in the fridge.
The lightbulb in the fridge allows you to see into the depths of the fridge. Just like regular lightbulbs in your light fixtures throughout your house can stop working, so can the fridge’s lightbulb.
Be careful when removing the lightbulb as it is glass and can shatter if too much pressure is applied.
必要な工具と部品
Pull the refrigerator out from the wall until you can safely slide behind it.
Unplug the refrigerator from its power source. This is normally found directly behind the refrigerator, just firmly grasp the plug and remove.
ある他の人がこのガイドを完成しました。
