メインコンテンツにスキップ
Whirlpool WRS571CIHV00 Lightbulb Replacement
アーカイブされたガイド
このガイドは将来的な使用のためにのみ保存されてます。ご自身の修理作業には更新バージョンをご利用ください。
必要な工具と部品
  1. Whirlpool WRS571CIHV00 Lightbulb  Replacement, Lightbulb: 手順 1、 2の画像 1 Whirlpool WRS571CIHV00 Lightbulb  Replacement, Lightbulb: 手順 1、 2の画像 2
    • Pull the refrigerator out from the wall until you can safely slide behind it.
    • Unplug the refrigerator from its power source. This is normally found directly behind the refrigerator, just firmly grasp the plug and remove.
  2. Whirlpool WRS571CIHV00 Lightbulb  Replacement: 手順 2、 2の画像 1 Whirlpool WRS571CIHV00 Lightbulb  Replacement: 手順 2、 2の画像 2
    • Using the Phillips #1 screwdriver, remove the 1/2'' screw holding the plastic cover in place.
  3. Whirlpool WRS571CIHV00 Lightbulb  Replacement: 手順 3、 1の画像 1
    • Pull back the plastic cover with your hand as shown in the figure.
    • You will want to hold this piece back for the next few steps as indicated in each step.
  4. Whirlpool WRS571CIHV00 Lightbulb  Replacement: 手順 4、 1の画像 1
    • Twist the lightbulb to the left to loosen it from the receptacle.
    • You will still need to hold the plastic housing back so you can access the lightbulb.
  5. Whirlpool WRS571CIHV00 Lightbulb  Replacement: 手順 5、 1の画像 1
    • Once loosened, remove the lightbulb from the receptacle and throw it away.
    • The lightbulb is fragile; therefore, handle it with care.
    • Again, your other hand will still be holding the plastic housing back from the receptacle.
  6. Whirlpool WRS571CIHV00 Lightbulb  Replacement: 手順 6、 1の画像 1
    • Place the appropriate wattage and size lightbulb into the receptacle.
    • Whirlpool recommends a 2.0 or 3.6 watt lightbulb.
    • Using your other hand, continue to hold the plastic housing back to have better access to the receptacle.
  7. Whirlpool WRS571CIHV00 Lightbulb  Replacement: 手順 7、 1の画像 1
    • Twist the lightbulb to the right to tighten the bulb back into the receptacle.
    • Your other hand should still be holding the plastic housing back.
  8. Whirlpool WRS571CIHV00 Lightbulb  Replacement: 手順 8、 1の画像 1
    • Use the Phillips #1 to replace the 1/2'' screw back into the plastic cover and tighten it by twisting to the right.
  9. Whirlpool WRS571CIHV00 Lightbulb  Replacement: 手順 9、 1の画像 1
    • Slide behind the refrigerator and place the plug back into the outlet.
    • To place the plug back in, align the prongs with the holes in the outlet and push until the plug is seated firmly against the outlet.
    • Push the refrigerator back against the wall.
    • It is important to not push the refrigerator all the way against the wall. In other words, leave an inch to a half a inch between the back of the refrigerator and wall.
終わりに
ある他の人がこのガイドを完成しました。
作成者
4人の作成者と共同で作成されました。
Calie Eldred
メンバー登録日: 10/08/20
193 ポイント
1ガイドが承認済み
チーム
University of Memphis, Team S3-G12, Willis Fall 2020 University of Memphis, Team S3-G12, Willis Fall 2020人のメンバー
UM-WILLIS-F20S3G12
1 メンバー
2のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 7
今までの合計 628
