メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Whirlpool Refrigerator Water Inlet Valve Replacement
必要な工具と部品
  1. Whirlpool Refrigerator Water Inlet Valve Replacement, Safety precautions: 手順 1、 1の画像 1
    • Before you begin your repair, perform the following:
    • Turn off your main water supply
    • Unplug your device
  2. Whirlpool Refrigerator Water Inlet Valve Replacement, Unfasten the rear panel: 手順 2、 3の画像 1 Whirlpool Refrigerator Water Inlet Valve Replacement, Unfasten the rear panel: 手順 2、 3の画像 2 Whirlpool Refrigerator Water Inlet Valve Replacement, Unfasten the rear panel: 手順 2、 3の画像 3
    • Remove the screw(s) securing the rear panel.
    • Loosen the screw securing the water hose enough for the rear panel to freely move.
  3. Whirlpool Refrigerator Water Inlet Valve Replacement, Remove the rear panel: 手順 3、 3の画像 1 Whirlpool Refrigerator Water Inlet Valve Replacement, Remove the rear panel: 手順 3、 3の画像 2 Whirlpool Refrigerator Water Inlet Valve Replacement, Remove the rear panel: 手順 3、 3の画像 3
    • Pull the rear panel off the chassis to remove it.
  4. Whirlpool Refrigerator Water Inlet Valve Replacement, Remove the clip: 手順 4、 2の画像 1 Whirlpool Refrigerator Water Inlet Valve Replacement, Remove the clip: 手順 4、 2の画像 2
    • Use needle nose pliers, or your fingers, to remove the plastic clip on the inlet valve assembly.
  5. Whirlpool Refrigerator Water Inlet Valve Replacement, Disconnect the front water hose: 手順 5、 3の画像 1 Whirlpool Refrigerator Water Inlet Valve Replacement, Disconnect the front water hose: 手順 5、 3の画像 2 Whirlpool Refrigerator Water Inlet Valve Replacement, Disconnect the front water hose: 手順 5、 3の画像 3
    • Push the plastic ring above the front water hose to release its clips.
    • As you push the ring, pull the water hose downward to disconnect it.
    • Repeat the disconnection procedure for the other water hose on the inlet valve assembly.
  6. Whirlpool Refrigerator Water Inlet Valve Replacement, Unfasten the inlet valve assembly: 手順 6、 1の画像 1
    • Remove the screw(s) securing the inlet valve assembly.
  7. Whirlpool Refrigerator Water Inlet Valve Replacement, Reposition the inlet valve assembly: 手順 7、 3の画像 1 Whirlpool Refrigerator Water Inlet Valve Replacement, Reposition the inlet valve assembly: 手順 7、 3の画像 2 Whirlpool Refrigerator Water Inlet Valve Replacement, Reposition the inlet valve assembly: 手順 7、 3の画像 3
    • Pull the inlet valve assembly off its slot in the chassis and rest it on the floor.
  8. Whirlpool Refrigerator Water Inlet Valve Replacement: 手順 8、 2の画像 1 Whirlpool Refrigerator Water Inlet Valve Replacement: 手順 8、 2の画像 2
    • Place a clean and dry rag under the inlet valve assembly before continuing.
  9. Whirlpool Refrigerator Water Inlet Valve Replacement, Remove the clip: 手順 9、 2の画像 1 Whirlpool Refrigerator Water Inlet Valve Replacement, Remove the clip: 手順 9、 2の画像 2
    • Use needle nose pliers, or your hands, to pull the clip off the rear water hose.
  10. Whirlpool Refrigerator Water Inlet Valve Replacement: 手順 10、 3の画像 1 Whirlpool Refrigerator Water Inlet Valve Replacement: 手順 10、 3の画像 2 Whirlpool Refrigerator Water Inlet Valve Replacement: 手順 10、 3の画像 3
    • Push the yellow plastic ring above the rear water hose to release its clips.
    • As you push the ring, pull the water hose away from the inlet valve assembly to disconnect it.
  11. Whirlpool Refrigerator Water Inlet Valve Replacement, Disconnect the assembly wire connector: 手順 11、 3の画像 1 Whirlpool Refrigerator Water Inlet Valve Replacement, Disconnect the assembly wire connector: 手順 11、 3の画像 2 Whirlpool Refrigerator Water Inlet Valve Replacement, Disconnect the assembly wire connector: 手順 11、 3の画像 3
    • Use a flathead screwdriver, or a similar tool, to disconnect any wire connectors attached to the inlet valve assembly.
  12. Whirlpool Refrigerator Water Inlet Valve Replacement, Remove the inlet valve assembly: 手順 12、 1の画像 1
    • Remove the inlet valve assembly from the chassis.
  13. Whirlpool Refrigerator Water Inlet Valve Replacement, Meter the inlet valve assembly: 手順 13、 1の画像 1
    • If you own a multimeter, you can test your inlet valve assembly's resistance.
    • A range between 500–1.5 kΩ is acceptable.
終わりに
Repair didn’t go as planned? Ask our Answers community for help.
ある他の人がこのガイドを完成しました。
作成者
3人の作成者と共同で作成されました。
nicO
メンバー登録日: 04/14/15
15,990 ポイント
89のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 21
過去 7 日: 98
過去 30 日: 416
今までの合計 13,707
