メインコンテンツにスキップ
Whirlpool Refrigerator Auger Motor Replacement
必要な工具と部品
  1. Whirlpool Refrigerator Auger Motor Replacement, Safety precautions: 手順 1、 1の画像 1
    • Before you begin your repair, perform the following:
    • Turn off your main water supply
    • Unplug your device
  2. Whirlpool Refrigerator Auger Motor Replacement, Open the doors: 手順 2、 3の画像 1 Whirlpool Refrigerator Auger Motor Replacement, Open the doors: 手順 2、 3の画像 2 Whirlpool Refrigerator Auger Motor Replacement, Open the doors: 手順 2、 3の画像 3
    • Depending on your repair, open one or both doors.
  3. Whirlpool Refrigerator Auger Motor Replacement, Remove the icemaker tray: 手順 3、 2の画像 1 Whirlpool Refrigerator Auger Motor Replacement, Remove the icemaker tray: 手順 3、 2の画像 2
    • Pull the icemaker tray completely out of its slot in the chassis.
  4. Whirlpool Refrigerator Auger Motor Replacement, Unfasten the icemaker assembly: 手順 4、 2の画像 1 Whirlpool Refrigerator Auger Motor Replacement, Unfasten the icemaker assembly: 手順 4、 2の画像 2
    • Remove the screw(s) securing the icemaker assembly.
    • The second photo shows the potential screw locations in a removed icemaker assembly.
  5. Whirlpool Refrigerator Auger Motor Replacement, Reposition the icemaker assembly: 手順 5、 3の画像 1 Whirlpool Refrigerator Auger Motor Replacement, Reposition the icemaker assembly: 手順 5、 3の画像 2 Whirlpool Refrigerator Auger Motor Replacement, Reposition the icemaker assembly: 手順 5、 3の画像 3
    • Pull the icemaker assembly off its slot in the chassis.
    • Let the assembly hang to access its connectors.
  6. Whirlpool Refrigerator Auger Motor Replacement, Disconnect the icemaker assembly: 手順 6、 3の画像 1 Whirlpool Refrigerator Auger Motor Replacement, Disconnect the icemaker assembly: 手順 6、 3の画像 2 Whirlpool Refrigerator Auger Motor Replacement, Disconnect the icemaker assembly: 手順 6、 3の画像 3
    • Disconnect any connectors attached to the icemaker assembly.
  7. Whirlpool Refrigerator Auger Motor Replacement, Remove the icemaker assembly: 手順 7、 1の画像 1
    • Remove the icemaker assembly.
  8. Whirlpool Refrigerator Auger Motor Replacement, Unfasten the icemaker auger assembly: 手順 8、 1の画像 1
    • Remove the screw(s) securing the icemaker auger assembly.
  9. Whirlpool Refrigerator Auger Motor Replacement, Reposition the icemaker auger assembly: 手順 9、 3の画像 1 Whirlpool Refrigerator Auger Motor Replacement, Reposition the icemaker auger assembly: 手順 9、 3の画像 2 Whirlpool Refrigerator Auger Motor Replacement, Reposition the icemaker auger assembly: 手順 9、 3の画像 3
    • Pull the icemaker auger assembly off of its slot in the chassis.
  10. Whirlpool Refrigerator Auger Motor Replacement, Disconnect the icemaker auger assembly: 手順 10、 3の画像 1 Whirlpool Refrigerator Auger Motor Replacement, Disconnect the icemaker auger assembly: 手順 10、 3の画像 2 Whirlpool Refrigerator Auger Motor Replacement, Disconnect the icemaker auger assembly: 手順 10、 3の画像 3
    • Disconnect any connectors attached to the icemaker auger assembly.
  11. Whirlpool Refrigerator Auger Motor Replacement, Remove the icemaker auger assembly: 手順 11、 1の画像 1
    • Remove the icemaker auger assembly.
  12. Whirlpool Refrigerator Auger Motor Replacement, Remove the auger fin: 手順 12、 3の画像 1 Whirlpool Refrigerator Auger Motor Replacement, Remove the auger fin: 手順 12、 3の画像 2 Whirlpool Refrigerator Auger Motor Replacement, Remove the auger fin: 手順 12、 3の画像 3
    • Twist the auger fin clockwise until it separates from the assembly.
    • Remove the auger fin.
  13. Whirlpool Refrigerator Auger Motor Replacement, Unfasten the grounding wire: 手順 13、 1の画像 1
    • Remove the screw(s) securing the grounding wire.
  14. Whirlpool Refrigerator Auger Motor Replacement, Unfasten the auger motor: 手順 14、 1の画像 1
    • Remove the screw(s) securing the auger motor.
  15. Whirlpool Refrigerator Auger Motor Replacement, Disconnect the auger motor: 手順 15、 2の画像 1 Whirlpool Refrigerator Auger Motor Replacement, Disconnect the auger motor: 手順 15、 2の画像 2
    • Use needle nose pliers, or your hands, to disconnect the grounding wire from the auger motor.
  16. Whirlpool Refrigerator Auger Motor Replacement: 手順 16、 3の画像 1 Whirlpool Refrigerator Auger Motor Replacement: 手順 16、 3の画像 2 Whirlpool Refrigerator Auger Motor Replacement: 手順 16、 3の画像 3
    • Disconnect the connectors attached to the auger motor.
  17. Whirlpool Refrigerator Auger Motor Replacement, Only the auger motor remains: 手順 17、 1の画像 1
    • You're now left with the auger motor.
  18. Whirlpool Refrigerator Auger Motor Replacement, Meter the auger motor: 手順 18、 1の画像 1
    • If you own a multimeter, you can test your auger motor's resistance.
    • A range between 5-50 Ω is acceptable.
終わりに
Repair didn’t go as planned? Ask our Answers community for help.
作成者
2人の作成者と共同で作成されました。
nicO
メンバー登録日: 04/14/15
15,945 ポイント
89のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 11
過去 30 日: 36
今までの合計 2,156
