メインコンテンツにスキップ
What to do if your iPhone 6 or 6 Plus won't respond to touch
必要な工具と部品
  1. What to do if your iPhone 6 or 6 Plus won't respond to touch, Check for bars: 手順 1、 1の画像 1
    • In gambling, three bars are considered to be a sign you've won. Not in this case. If your phone shows a white bar across the top of the screen it's a sure sign you've got Touch Disease. Take it to a repair shop where they can fix the broken solder.
    • It is possible to bend the phone back into place to restore touch functionality, however this solution is only temporary and the real issue will resurface, perhaps at a more inopportune time. Think of it like running on a spare tire, you shouldn't use a bandaid for long.
  2. What to do if your iPhone 6 or 6 Plus won't respond to touch, Check for bending: 手順 2、 1の画像 1
    • If you're prone to putting your phone in your pocket when you sit down it may have gradually changed it's shape to develop a slight curve. This curve can be causing the touch issues.
    • A bend in your phone, slight or more pronounced like in this picture, along with intermittent touch issues can be indicative of "Touch Disesase" even if you don't have the telltale bar as mentioned in Step 1.
  3. What to do if your iPhone 6 or 6 Plus won't respond to touch, Try a replacement screen: 手順 3、 1の画像 1
    • If you've got a cracked screen and faulty touch issues, or recently dropped the phone, your first step should be to check with a replacement screen installation. Use an iFixit Guide to learn how to install the screen, and see if a replacement fixes the problem.
    • Even if your screen isn't cracked, the issue could still be related to a damaged screen that just needs to be replaced.
    • Similarly, if a replacement screen solves the problem it may resurface down the line after a few hours or days. This is less likely a defective screen and more likely an issue with "Touch Disease" affecting your phone.
終わりに
If you see bars, or a bend, check out a repair shop to ensure your solder on your device isn't weakening.
30 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
Matt Zieminski
メンバー登録日: 02/23/15
8,427 ポイント
3のガイドは作成済み
チーム
Master Techs Master Techs人のメンバー
Community
311 メンバー
1,197のガイドは作成済み
16 件のコメント
"...you've got Touch Disease. Take it to a repair shop."
...and have them do what?
William Totman - 返信
Hey that's a good point! A repair shop can generally fix this by fixing the solder, the point of failure in these devices. It won't necessarily protect it forever from having the same issue but it will restore functionality for the foreseeable future. I'll update the guide to detail that!
Matt Zieminski -
Which chip exactly are they soldering?
Nemesio Diego - 返信
One or both of these https://instagram.com/p/BCq2pPQitTN/
U2401 and U2402
Trent -
90% of the time we replace the Meson Touch IC on the iphone 6 plus and that resolves the issue. https://www.instagram.com/p/BL1HCQTg2rk/...
Wires Computing - 返信
コメントを追加
統計データ:
過去 24時間: 4
過去 7 日: 27
過去 30 日: 84
今までの合計 26,686
