メインコンテンツにスキップ
What’s the best way to wash and dry my Vaude softshell jacket?
必要な工具と部品
  1. What’s the best way to wash and dry my Vaude softshell jacket?, Read the care label on the product: 手順 1、 2の画像 1 What’s the best way to wash and dry my Vaude softshell jacket?, Read the care label on the product: 手順 1、 2の画像 2
    • Set the washing machine to 30 °C with a gentle cycle. There are symbols for the recommended care products on the smaller label. We recommend Nikwax Tech Wash for the washing cycle and TX Direct Spray from Nikwax for waterproofing if necessary.
    • Details to the care symbols for washing, bleaching, drying or ironing you will find here: http://help.vaude.com/care-instructions/...
  2. What’s the best way to wash and dry my Vaude softshell jacket?: 手順 2、 1の画像 1
    • Fill the washing machine. For optimal results you should wash similar colors together.
    • Please always close buttons, zippers and Velcro closures before washing. This keeps fibers from catching and the clothing from stretching out during the wash cycle.
  3. What’s the best way to wash and dry my Vaude softshell jacket?, Washing: 手順 3、 2の画像 1 What’s the best way to wash and dry my Vaude softshell jacket?, Washing: 手順 3、 2の画像 2
    • Set the washing machine to the cycle and temperature recommended on the apparel. In our example it’s 30 °C and a gentle cycle. Put the correct amount of liquid in the dispenser depending on the hardness of your water. You can find out how much you should use by reading the instructions on the care product.
    • Do not use fabric softener or bleach!
  4. What’s the best way to wash and dry my Vaude softshell jacket?, Drying: 手順 4、 2の画像 1 What’s the best way to wash and dry my Vaude softshell jacket?, Drying: 手順 4、 2の画像 2
    • For optimal reactivation of the waterproofing (DWR), put the clothing into the dryer for 30 to 50 minutes after washing. Alternatively, you can air dry the clothing in a warm and dry place, however, the waterproofing will not be reactivated.
  5. What’s the best way to wash and dry my Vaude softshell jacket?, Waterproofing if necessary: 手順 5、 1の画像 1
    • If the waterproofing has been reduced with time, you can treat your jacket with a spray-on waterproofing. We recommend the spray on product from Nikwax for softshell products.
    • Please follow the instructions printed on the care product.
ゴール
3 の人々がこのガイドを完成させました。
以下の翻訳者の皆さんにお礼を申し上げます:
de en
100%
これらの翻訳者の方々は世界を修理する私たちのサポートをしてくれています。 あなたも貢献してみませんか?
翻訳を始める ›
作成者
1人の作成者と共同作成されました。
VAUDE Reparaturteam
メンバー登録日: 02/22/16
6,255 ポイント
32のガイドは作成済み
チーム
Vaudesport Vaudesport人のメンバー
Community
3 メンバー
96のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 5
過去 30 日: 20
今までの合計 2,257
