メインコンテンツにスキップ
Wexford CT-166TF Plastic Casing Replacement
必要な工具と部品
  1. Wexford CT-166TF Plastic Casing  Replacement, Settings Knob: 手順 1、 1の画像 1
    • Locate the knob at the top of the fan.
  2. Wexford CT-166TF Plastic Casing  Replacement: 手順 2、 1の画像 1
    • Remove the knob by gripping it and pulling straight up. Use a spudger if it is difficult to grip.
    • When reassembling, be sure to align the bottom of the new knob and the turning mechanism in the fan before pushing down.
  3. Wexford CT-166TF Plastic Casing  Replacement, Plastic Casing: 手順 3、 1の画像 1
    • Using the plastic opening tool, turn the device over and remove the black plastic covers over the four screw holes.
  4. Wexford CT-166TF Plastic Casing  Replacement: 手順 4、 2の画像 1 Wexford CT-166TF Plastic Casing  Replacement: 手順 4、 2の画像 2
    • Remove the four screws underneath the plastic covers.
  5. Wexford CT-166TF Plastic Casing  Replacement: 手順 5、 2の画像 1 Wexford CT-166TF Plastic Casing  Replacement: 手順 5、 2の画像 2
    • Remove 5 smaller screws visible through small holes between the base and the casing.
  6. Wexford CT-166TF Plastic Casing  Replacement: 手順 6、 2の画像 1 Wexford CT-166TF Plastic Casing  Replacement: 手順 6、 2の画像 2
    • Remove four screws on the back, two near the top and two near the bottom.
  7. Wexford CT-166TF Plastic Casing  Replacement: 手順 7、 1の画像 1
    • Pull off the back casing.
  8. Wexford CT-166TF Plastic Casing  Replacement: 手順 8、 2の画像 1 Wexford CT-166TF Plastic Casing  Replacement: 手順 8、 2の画像 2
    • Remove the 2 screws that attach the front part of the casing to the motor.
  9. Wexford CT-166TF Plastic Casing  Replacement: 手順 9、 2の画像 1 Wexford CT-166TF Plastic Casing  Replacement: 手順 9、 2の画像 2
    • Remove the two middle screws attaching the black plastic cover to the front .
  10. Wexford CT-166TF Plastic Casing  Replacement: 手順 10、 1の画像 1
    • Remove the two screws attached to the white bar near the red light on the top of the front casing.
  11. Wexford CT-166TF Plastic Casing  Replacement: 手順 11、 1の画像 1
    • Remove the two screws keeping the button attached to the top of the casing.
終わりに
ある他の人がこのガイドを完成しました。
作成者
3人の作成者と共同で作成されました。
Cameron Mattson
メンバー登録日: 04/05/17
101 ポイント
1ガイドが承認済み
チーム
UW Tacoma, Team S3-G4, Liner Spring 2017 UW Tacoma, Team S3-G4, Liner Spring 2017人のメンバー
UWT-LINER-S17S3G4
4 メンバー
3のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 7
過去 30 日: 14
今までの合計 342
