メインコンテンツにスキップ
Weiser Smartcode 10 Touchscreen Electronic Lock Battery Replacement
必要な工具と部品
  1. Weiser Smartcode 10 Touchscreen Electronic Lock Battery Replacement, Battery: 手順 1、 1の画像 1
    • Unlock your door and open it.
    • Make sure the bolt/latch is fully inside the door before you continue.
  2. Weiser Smartcode 10 Touchscreen Electronic Lock Battery Replacement: 手順 2、 1の画像 1
    • Using the Phillips #1 screwdriver, remove the three 8 mm screws on the left, right and bottom side of the cover.
  3. Weiser Smartcode 10 Touchscreen Electronic Lock Battery Replacement: 手順 3、 1の画像 1
    • Take the exterior cover off of the door lock.
  4. Weiser Smartcode 10 Touchscreen Electronic Lock Battery Replacement: 手順 4、 2の画像 1 Weiser Smartcode 10 Touchscreen Electronic Lock Battery Replacement: 手順 4、 2の画像 2
    • Find the battery pack (marked "DOOR" in between two arrows) at the top of the lock.
  5. Weiser Smartcode 10 Touchscreen Electronic Lock Battery Replacement: 手順 5、 2の画像 1 Weiser Smartcode 10 Touchscreen Electronic Lock Battery Replacement: 手順 5、 2の画像 2
    • Slide the battery pack upwards.
    • Turn the pack over to reveal the batteries.
    • Replace the four AA batteries.
  6. Weiser Smartcode 10 Touchscreen Electronic Lock Battery Replacement: 手順 6、 1の画像 1
    • Reinsert the battery pack with the word "DOOR" facing you.
    • Wait until you see a green LED light flashing and/or hear two beeps to indicate working batteries.
    • If there is no green light, repeat steps 5 and 6. Check to see if the batteries are placed correctly or if newer batteries are required.
  7. Weiser Smartcode 10 Touchscreen Electronic Lock Battery Replacement: 手順 7、 1の画像 1
    • Check that the bolt/latch is still inside the door.
    • Take the exterior cover and point the narrow end of the knob to the right.
    • Place the cover on the lock and reinsert the screws.
    • Try not to fasten the screws too tightly as they could get damaged in the process.
  8. Weiser Smartcode 10 Touchscreen Electronic Lock Battery Replacement: 手順 8、 2の画像 1 Weiser Smartcode 10 Touchscreen Electronic Lock Battery Replacement: 手順 8、 2の画像 2
    • To confirm the finished repair, go to the front of the door and place the back of your hand on the touchscreen to activate the keypad.
終わりに
Congratulations! Make sure to redo this process each year to ensure your device continues to work!
2 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
Brandon Brown
メンバー登録日: 05/15/21
214 ポイント
1ガイドが承認済み
チーム
York University, Team S1-G7, Melo-Thaiss Summer 2021 York University, Team S1-G7, Melo-Thaiss Summer 2021人のメンバー
YORK-MELO-THAISS-SU21S1G7
1 メンバー
2のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 4
過去 7 日: 37
過去 30 日: 170
今までの合計 7,555
