メインコンテンツにスキップ
Weinmann VENTImotion and VENTIlogic Power Board Replacement
医療機器
この修理ガイドは医療機器メーカーからの是認を得ておらず、iFixitと医療機器メーカーは提携していません。
  1. Weinmann VENTImotion and VENTIlogic Power Board Replacement, Power Board: 手順 1、 2の画像 1 Weinmann VENTImotion and VENTIlogic Power Board Replacement, Power Board: 手順 1、 2の画像 2
    • Open the Device by following these steps:
    • Open the device only with the power supply plug disconnected.
    • Place the device on a non-slip surface with the top facing downwards.
    • Remove the filter cassette from the top part of the housing
    • Undo and remove the 6 screws (34)
    • Open the bottom part of the housing (35) away to the side.
    • Undo the connecting cables for the humidifier (42) and the alarm (43)
    • You can now put the bottom part of the housing (35) to one side.
  2. Weinmann VENTImotion and VENTIlogic Power Board Replacement: 手順 2、 1の画像 1
    • Disconnect the power board connecting cable (45) from the power board (41).
  3. Weinmann VENTImotion and VENTIlogic Power Board Replacement: 手順 3、 1の画像 1
    • Disconnect the Motor Cable
  4. Weinmann VENTImotion and VENTIlogic Power Board Replacement: 手順 4、 1の画像 1
    • Disconnect the O2 valve/power board connecting cable (70) from the power board.
    • Disconnect all connecting cables from the control board.
    • Remove the power board from the top part of the housing.
  5. Weinmann VENTImotion and VENTIlogic Power Board Replacement: 手順 7、 1の画像 1
    • Take the rechargeable battery connecting cable (48) out of the groove and disconnect it from the power board (41).
  6. Weinmann VENTImotion and VENTIlogic Power Board Replacement: 手順 8、 1の画像 1
    • Disconnect the cables of the old power board and plug them into the appropriate slots of the new power board 41:
    • –power board/control board connecting cable (46)
    • –rechargeable battery connecting cable (48)
    • –earth cable (47)
  7. Weinmann VENTImotion and VENTIlogic Power Board Replacement: 手順 9、 2の画像 1 Weinmann VENTImotion and VENTIlogic Power Board Replacement: 手順 9、 2の画像 2
    • Connect the power board/mains supply unit connecting cable (45) to the new power board.
    • Position the new power board in the top part of the housing.
  8. Weinmann VENTImotion and VENTIlogic Power Board Replacement: 手順 11、 1の画像 1
    • Restore the connections to the control board.
終わりに
ある他の人がこのガイドを完成しました。
作成者
2人の作成者と共同で作成されました。
Emily Jacobson
メンバー登録日: 04/06/20
288 ポイント
1ガイドが承認済み
チーム
Cal Poly, Team S7-G19, Paton Spring 2020 Cal Poly, Team S7-G19, Paton Spring 2020人のメンバー
CPSU-PATON-S20S7G19
3 メンバー
4のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 4
過去 30 日: 9
今までの合計 212
